CEL and ABS Help
Old Sep 16, 2007 | 04:56 PM
steveo135's Avatar
Default CEL and ABS Help
So friday i picked up a 97' teg from out of state and before i go registering it and through emissions i want to get the CEL and ABS lights dealt with...
1. CEL is throwing code 65 which is O2 sensor heater...
the kid before me put in a test pipe so if i just go back to a cat and hook the o2 back up it should be fine right?
and...
2. ABS is throwing a code 74 which is solenoid - R
what the hell does that mean and what do i do to fix...
any help or a point in the right direction would help a lot... thanks in advance...
Old Sep 16, 2007 | 05:54 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: CEL and ABS Help (steveo135)
The ABS code means that your ABS modulator is most likely failing. The rear channel solenoid is not working properly. You most likely will need a new modulator.
The CEL sounds like the heater circuit or wiring to the O2 sensor is faulty. Get under the car and look for hacked harnesses.
Old Sep 20, 2007 | 10:25 AM
steveo135's Avatar
Default Re: CEL and ABS Help (Dogginator)
thanks! anyone else have any ideas?
Old Sep 21, 2007 | 11:03 AM
steveo135's Avatar
help
Wayne_Curr
Apr 13, 2006 03:07 PM
alphabeatsco2004
Aug 16, 2005 07:28 PM
mikeyy
Nov 2, 2003 02:28 PM
vti-R
Dec 26, 2001 08:59 AM
