Car shaking problem
Old Feb 3, 2010 | 02:25 PM
thunderboy's Avatar
Default Car shaking problem
Hi, my car begin shaking when I go at a fast speed.What can be the problem??
Old Feb 3, 2010 | 02:37 PM
sde780's Avatar
Default Re: Car shaking problem
low VTEC fluid
tire balance
alignment
Old Feb 3, 2010 | 02:59 PM
variable's Avatar
Bad Tire(s)
Bad Alignment
wheel(s) need balanced
wheel(s) are bent
worn suspension bushing(s)
damaged suspension part(s)
needs Type R front lip
Old Feb 3, 2010 | 03:34 PM
dothacker's Avatar
lol @ needs type R front lip
bad axles can make your car shake too. also, bad inner and / or outer tie rod ends.
Old Feb 4, 2010 | 12:27 AM
nathan_559's Avatar
def check ur tires first
Old Feb 4, 2010 | 02:39 AM
dothacker's Avatar
definitely do this first. they could be out of round also. go to ur local discount tire or if you know someone who can balance your wheels. once they spin that on the machine, you'll see if your tire is OOR or not.
Old Feb 9, 2010 | 05:02 PM
thunderboy's Avatar
can it be also my front rotors (disc brake)
Old Feb 9, 2010 | 06:24 PM
mouab18c1's Avatar
Originally Posted by sde780
low VTEC fluid
tire balance
alignment
WTF??? ahahah...
but on with your issue.what do you mean by fast? 60mph? higher lower? tire pressure comes to play, bad axles, wheel bearings. my issue with rotors is that if they are warped your car would only shake when coming to a hard stop.
Old Feb 9, 2010 | 06:28 PM
Dave-ROR's Avatar
Most likely a tire/balance issue.
Old Feb 9, 2010 | 06:44 PM
94VTECoupe's Avatar
If its your tires, it will be whether you're on the throttle or not. Visually inspect your tires for bulges etc.
If its your brakes... It will only happen when you step on the brakes...
If its your axles or your intermediate shaft bearing/support, it will only happen when you step on the throttle.
These are pretty much the only things that can cause your car to shake at speed.... Unless you have bad muffler bearings, but I would hope you've already checked that.
Old Feb 9, 2010 | 06:46 PM
Dave-ROR's Avatar
Really, so wheel and tire balance won't make it shake huh?
That's some things that can cause a shake, but certainly not all of them.
Old Feb 10, 2010 | 05:42 AM
dothacker's Avatar
muffler bearings? didn't know mufflers have bearings in them...
Old Feb 10, 2010 | 07:17 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Once again, a joke. Come on guys.
If it shakes with the throttle open only, then 99.94% of the time it's one or both of the inner CV joints gone bad.
Old Feb 10, 2010 | 07:21 AM
Dave-ROR's Avatar
He actually never said with the throttle open only, just "go at a fast speed" which could mean cruising at 60mph, etc..
Old Feb 10, 2010 | 07:25 AM
Community Builder
Yes I know that, which is why I said if the throttle is open, then....
Old Feb 10, 2010 | 03:13 PM
2fast4urass's Avatar
try getting strut bars, start tri bar it connects from your fire to your front upper shock mounts and good luck man
Old Feb 10, 2010 | 05:25 PM
Community Builder
uh no that will do absolutely nothing
Old Feb 10, 2010 | 07:13 PM
dothacker's Avatar
... i really dont know what this guy is thinking...
anyways, go to O'Reilly auto parts and get the MASTER PRO SELECT CV Axles . they're brand new axles and stay away from remanufactured axles. also, this comes with lifetime warranty
Old Feb 11, 2010 | 06:44 AM
jimjampants's Avatar
really i cant believe this is a real post. just pay a few bucks and get ur tires balanced. If yu have an issue still, get new ones. If your problem doesnt go away ill show u naked pics of my girlfriends lol. and also if you didnt change your muffler bearing yet then do that.
dem0nk1d
13
Nov 3, 2010 02:01 PM
Just_LS
Apr 26, 2006 07:41 PM
rota power
Apr 11, 2006 07:03 PM
aces1980
Jan 23, 2005 05:31 PM
Freelance-GSR
Aug 4, 2002 12:22 PM
