car doesnt start?
Old Dec 22, 2004 | 08:20 PM
KingJeff's Avatar
Default car doesnt start?
my car doesnt start. I heard clicking and i asked around. people said it was the starter so i put a new one in. IT still doesnt start....is it the battery??
Old Dec 22, 2004 | 08:30 PM
purplegsr's Avatar
Default Re: car doesnt start? (Jeff K.)
try your friends battery you mentioned in the other thread, if it doesn't work, it could also be your alternator or your battery cables (if they are old and corroded they won't work well either).
Old Dec 22, 2004 | 08:41 PM
KingJeff's Avatar
Default Re: car doesnt start? (purplegsr (Exospeed))
yeah...my friend also said it could be the alternator. An alternator is pretty expensive right?
Old Dec 22, 2004 | 08:46 PM
Senbonzakura's Avatar
Depends on what alternator you want. Different alternator outputs different amps.
I'm sure its pretty cheap for you.
Old Dec 22, 2004 | 11:06 PM
Sack Master's Avatar
Default Re: car doesnt start? (Kyo Kusanagi)
Does the battery have juice? If so your grounds are the first thing to check.
Old Dec 23, 2004 | 05:29 PM
KingJeff's Avatar
Default Re: car doesnt start? (Sack Master)
i dont think it has juice. When we drove it my brother stalled. when he started it back up, it wouldnt start.
Old Dec 25, 2004 | 02:33 PM
KingJeff's Avatar
someone said it could be the belts not working right. could that be it?
Old Dec 25, 2004 | 03:45 PM
b16a2delsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote"> If so your grounds are the first thing to check.</TD></TR></TABLE>
if the belts weren't working right they would be squeaking.
Old Dec 25, 2004 | 04:04 PM
erikiksaz1's Avatar
Default Re: car doesnt start? (sn2bstteg)
Can you push start it? If the thing runs after push starting, i'd turn my attention to the battery or starter.
But, you said you changed out the starter, so maybe try a new battery?
Oh, and try disconnecting the positive to the battery when the car is running. If the car doesn't stall/stutter when it's removed, then your alternator should be alright.
I guess i've learned a few new things since my car stopped working
Old Dec 26, 2004 | 10:19 AM
KingJeff's Avatar
Default Re: car doesnt start? (erikiksaz1)
I havent tried push starting it, but it isnt the starter because i put a new one in. I also think the alternator is alright because i took the pos wire when it was running.
Integ808
Oct 16, 2008 02:57 AM
BoltonGSR
Jul 7, 2008 08:27 PM
tigueremalo
Jan 22, 2007 03:10 PM
calean
Nov 18, 2004 03:55 PM
ownedbyvtec
Aug 24, 2003 01:18 AM
