Car doesn't crank......
Old Mar 2, 2003 | 08:08 PM
mickey513's Avatar
Default Car doesn't crank......
Went to start my Integra today and it doesn't crank. There is power but the car doesn't crank. Anyone know what the problem is and how to fix it?
Old Mar 2, 2003 | 08:11 PM
tilt's Avatar
Default Re: Car doesn't crank...... (mickey513)
how much power is there? I would check the battery voltage, battery contacts, battery fluids level, then the starter.
Old Mar 2, 2003 | 08:13 PM
bryan305's Avatar
Default Re: Car doesn't crank...... (tilt)
Check for voltage at your starter connections. Then check for continuity between the starter and its ground. My friend's ground cable to starter corroded too much and wasn't letting it get any juice. They replaced the starter 3 times before they figured it out.
Old Mar 2, 2003 | 08:52 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Car doesn't crank...... (bryan305)
Do you hear anything at all when you turn the key? Do you hear a faint clicking? Do your accessories's lights turn off?
If so, check your main engine grounds like the others said. Check the main harness ground near the thermostat.
Also...just whack the end of the starter hard with a hammer. Actually, that sometimes works if the starter is a bit old or it's cold outside.
Good luck.
Old Mar 2, 2003 | 08:56 PM
The-LS's Avatar
sounds good there, also check any recent wiring you might have done like alarm related stuff.
Old Mar 2, 2003 | 11:28 PM
mickey513's Avatar
Default Re: Car doesn't crank...... (shamoo)
Good luck.
I do hear a slight "click" but the car doesn't crank and start. All it does is "click". I had experience this before, like at least a month already but all I did when this happen was just kept turning the key and it will evetually start.......until today. The dam things just keeps on making a "click" sound and won't start. I do have a DEI alarm installed on my Integra but that's been like a year, so I doubt it's that. I'll check the harness tomorrow morning and give the starter a whack with a hammer.
If that doesn't work, does it mean it's the starter?
Old Mar 2, 2003 | 11:31 PM
The-LS's Avatar
if power and connections is good, sounds like a starter... especially if wacking the starter helps
Old Mar 3, 2003 | 07:34 AM
InspiredRacer's Avatar
Default Re: Car doesn't crank...... (Black-R)
Sounds exactly like the starter ground. It got me for a week once. Check it first. Also check clutch positioning sensor
Old Mar 3, 2003 | 07:41 AM
Chris's Avatar
There is a SPADE connector to the starter, and a POWER connection. Sounds as if you SPADE connector has come off.
Old Mar 3, 2003 | 09:05 AM
LsPower's Avatar
What he said
Old Mar 3, 2003 | 09:08 AM
aznmc16's Avatar
Default Re: Car doesn't crank...... (LsPower)
try to jump start your car first.
Old Mar 3, 2003 | 09:30 AM
King_j's Avatar
Default Re: Car doesn't crank...... (aznmc16)
if the spade connector is off, then will anything happen? shouldnt nothing happen? i have this problem, sometimes it starts and sometimes it pisses me off.
Old Mar 3, 2003 | 07:08 PM
mickey513's Avatar
Ok, it's the STARTER. I checked the ground harness, the battery terminals (pos. was lose, had to put a piece of metal between the terminal and battery post to secure it tight.) I supect the terminal being lose shorted my starter and thus killed it. I also check the starter fuse and gave it a jump start. Nothing work until I wacked the starter a few times with a long metal stick. The car then starter. THANKS EVERYONE FOR THE HELP!
Anyone know where I can get a rebuilt or remanfacteur starter for a decent price? DOn't want to pay $200+ for one at my local auto-part store.
Old Mar 3, 2003 | 07:29 PM
aznmc16's Avatar
a rebuilt one plus trade of your messed up one will run you about $60 over where im at.. los angeles area. i would suggest going to an asian auto parts store
Aquila
20
Sep 28, 2016 05:59 PM
thirty3
Mar 23, 2013 11:14 AM
azandford
Apr 29, 2010 06:03 AM
Cwhiteg6
Jun 21, 2006 04:35 PM
mattL
Jun 25, 2002 07:33 PM
