Can't pull ABS code(s)???
Old Jun 6, 2014 | 05:31 PM
Dunc's Avatar
BCICAN
Default Can't pull ABS code(s)???
I have a '97 Integra LS with Hondata S300 and the ECU is on OBD1 (if that matters.) The car sat for about 2 years and I'm dusting it off now getting ready to sell it. I put new rotors on, but left the old Hawk HP+ pads because they have about 1/2 the pad remaining. My ABS light is on constantly. I just removed everything and wire wheeled the ring to clean it up and then wiped off the all the sensors.
The ABS light is still on. When I to use the jumper wire technique to pull codes, the light goes out and the check engine light comes on and stays solid. So how do I pull codes to figure out what the hell the problem or at least narrow down my search if the light goes away when using the jumper wire?
Old Jun 10, 2014 | 12:01 AM
xRec's Avatar
Default Re: Can't pull ABS code(s)???
i had this same problem i thought maybe the abs relay and that didnt work so my abs light is slill on HELP US!
Mines a 95 with stock ECU though
RotaryPWR
Aug 12, 2009 11:36 AM
GotVTEC07
Sep 23, 2007 05:05 AM
iLUVmyACCORD
Jan 14, 2005 06:13 AM
f22suzuka
Apr 21, 2004 10:15 AM
vain
Oct 16, 2003 03:26 AM
