Which cams do you recommend?
Old Mar 17, 2003 | 04:24 AM
2000GSR's Avatar
Default Which cams do you recommend?
I currently have i/h/e, I now want to move to the next modification. I'm looking into some cams but not sure which ones to get. I'm thinking about skunk 2 or toda b spec. I was told the type r cams or stage 1 cams will be a little on the mild side. I was wondering how much real power I would gain with stage 2 cams? Besides just dropping in the cams, what else is a must that I would need to compliment the cams? I don't plan on changing any internals just yet. I appreciate your responses.
Old Mar 17, 2003 | 04:45 AM
TEGME's Avatar
Default Re: Which cams do you recommend? (2000GSR)
If you are going to go with the stage 2s (or any other aggressive cams for that matter) it would be a good idea to bump up your compression. High lift cams love high compression.
Old Mar 17, 2003 | 05:03 AM
split917's Avatar
Default Re: Which cams do you recommend? (Jiz101)
check out these sites. depends on what your goals are. personally, i'm looking for something mild and want to avoid changing my internals. the sites below provide some good info.
http://www.jdmfan.com/articles/itr-cams_analyzed/
http://www.importreview.com/performance.html
Old Mar 17, 2003 | 05:20 AM
Davanca's Avatar
I think going with Toda's would be a good choice. They make good power. Also if you do choose Toda, make sure you do the valvetrain over, and get a stronger timing belt. It's not good to use those cams on a stock vavletrain.
Old Mar 17, 2003 | 05:51 AM
TEGME's Avatar
Default Re: Which cams do you recommend? (davanca24)
Yes, upgrade your valve train if you are going with the Todas or Stage 2s. To take full advantacge of these aggressive cams you will want to raise your redline.
Old Mar 17, 2003 | 07:26 AM
KoRE's Avatar
check out http://www.ef-1.com they offer cams and valvetrain and different applications depending on what your going for.
Old Mar 17, 2003 | 07:32 AM
G a b e's Avatar
Banned
Default Re: Which cams do you recommend? (KoRE)
If you are not going to upgrade your valvetrain, don't go with anything more aggressive than ITRs. You won't get any power out of the more agressive cams, unless you do some upgrading. Even Toda A's, and Skunk2 1's need at least an ITR valve train to put down some decent power.
Old Mar 17, 2003 | 07:50 AM
neo1z's Avatar
Default Re: Which cams do you recommend? (G a b e)
The Skunk2 Stage 1's are much different than itr cams...
Old Mar 17, 2003 | 09:32 AM
G a b e's Avatar
Banned
Default Re: Which cams do you recommend? (neo1z)
Yes, they are, but there have been people who have dropped them in their otherwise stock R's, and made some pretty good power out of them.
Old Mar 17, 2003 | 11:37 AM
Kellindal's Avatar
If you're not strengthening the internals, you shouldn't be getting new cams. Even if you step up to the Type-R cams, it's a good idea to bump up internals. I've heard good things from the Skunk cams, and of course Toda is an excellent choice. In my future, I see Skunk stage 1s or 2s with an upgraded valvetrain.
Old Mar 17, 2003 | 12:13 PM
integrx's Avatar
New User
Default Re: Which cams do you recommend? (Kellindal)
if you get cams, its a good idea to get the valve springs and retainer, cam gears, and somekind of afc
Old Mar 17, 2003 | 12:19 PM
gsrvx's Avatar
New User
what are ur goals?
Ruben19
Jan 24, 2006 07:25 PM
bounty359
34
Mar 29, 2005 06:13 PM
1750cc
Dec 18, 2004 04:35 PM
buggsy458
Sep 26, 2003 09:36 AM
