camber kits?
Old Apr 23, 2003 | 05:59 PM
xstalkrx's Avatar
Default camber kits?
why is it necessary to get a camber kit after dropping a car? Cant you just get it re alligned?
Old Apr 23, 2003 | 06:10 PM
xteg95's Avatar
Default Re: camber kits? (xstalkrx)
getting the car aligned will not make the car become like this | | again, will still be like this / \
VTECorona's Avatar
Alignment does not fix camber problems, it just aligns them so they are both 'parallel' to each-other.
Old Apr 23, 2003 | 06:14 PM
JackAcc's Avatar
Default Re: camber kits? (97RedTegGSR)
would a 1 to 1.5 inch drop require a camber kit?
Old Apr 23, 2003 | 06:19 PM
xstalkrx's Avatar
UGh...sorry i meant...if you have the camber re adjusted. I got my car alligned recently and they did the camber as well.
Old Apr 23, 2003 | 11:19 PM
tC_Dragon's Avatar
Default Re: camber kits? (JackAcc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JackAcc &raquo;</TD></TR><TR><TD CLASS="quote">would a 1 to 1.5 inch drop require a camber kit?</TD></TR></TABLE>
probably not.
Some argue that a camber kit is not needed... but my car did so i got one.. and i'm glad i did.
Old Apr 24, 2003 | 05:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xstalkrx &raquo;</TD></TR><TR><TD CLASS="quote">UGh...sorry i meant...if you have the camber re adjusted. I got my car alligned recently and they did the camber as well.</TD></TR></TABLE>
You must already have a camber kit then because it's not adjustable from the factory on a Civic or Integra.
I personally wouldn't want my tires to be straight up, negative camber can greatly aid handling abilities. I'm dropped about 2.5" w/o camber kit, no problems yet for the past 30K miles.
guero2craze
Suspension & Brakes
Feb 22, 2007 09:53 AM
h22a41997
Dec 15, 2006 05:29 PM
LoseRPunKx182
Suspension & Brakes
Aug 6, 2005 10:57 AM
tshaw
Dec 30, 2003 10:43 AM
SOHC_MShue
Jun 9, 2003 11:03 PM
