Camber Kit Question
Old Jul 10, 2003 | 12:27 AM
JMod's Avatar
Default Camber Kit Question
Sorry guys I know this is a newb question but what exactly is a camber kit for? From what i've gathered you use it basically when you lower your car, but i mean, does it change the angle of the tire so it doesn't rub, is it for handling, or what? thanks
Old Jul 10, 2003 | 12:57 AM
..::91TEG-G2::..'s Avatar
Default Re: Camber Kit Question (BucsJosh)
well from what i kinda know.. when u drop ur car, ur tires tend to tilt in a little bit.. which in the long run, will make you eat through your tires really quick... you'll ware them out then you'll be buying tires everytime.. but the camber kit helps u keep ur tires straight so they will lay flat on the floor.
thats from what i know.. but their might be other reasons to get a camber kit.. not sure
Old Jul 10, 2003 | 01:25 AM
NA gs-R 05 C
Guest
Posts: n/a
each time u lower or raise ur car, u will get camber (tire tilting inward or outward / positive or negative), a camber kit will be there so u can adjust it +/- according to what u want and etc.
having a lowered car, or u change ur suspension often or tracking, having 1 is really helpful.
Old Jul 10, 2003 | 02:24 AM
JMod's Avatar
Default Re: Camber Kit Question (NA gs-R 05 C)
alright thanks for the info fellas, i'm a newb and i'm just tryin to learn about all this stuff.
nhiczx
Jul 10, 2006 12:03 PM
xunkn0vvnx
Oct 5, 2005 10:16 AM
bryandamatrix
Jul 10, 2004 12:32 PM
wildstallion
Aug 21, 2002 09:56 AM
BoM
Jul 3, 2001 09:07 PM
