Camber kit problem(ingall type)
Old Feb 23, 2003 | 04:54 PM
lsinteg's Avatar
Default Camber kit problem(ingall type)
I installed a set of camber kit similar to the ingall kit on my 96teg yesterday and I notice there's a little jerk to the steering wheel whenever i m making a turn. All i can think of its the bushing is longer than the camber kit itself and causing a lateral movements to the upper control arms. Anyone having this problem?
Old Feb 23, 2003 | 05:38 PM
Racer X's Avatar
Default Re: Camber kit problem(ingall type) (lsinteg)
Sorry man, no troubles here. Maybe you should have it checked by a mechanic. It would suck if it got effed up.
Old Mar 10, 2003 | 04:37 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I assume you had the proper alignment done after installing this kit, correct? The bolts may have slipped, you can find out by lifting the front wheels off the ground and try to move the top of the tires in or out. If they move then you've got problems. I don't really know what to do about, other than getting a different kit or going back to stock. This is the #1 reason pretty much why I do not have a camber kit, it's just too much worry and hassle to deal with.
shackler
Dec 31, 2006 09:46 AM
Blu5GLude
Nov 11, 2002 05:37 PM
99ls
Aug 16, 2001 12:55 PM
