camber kit
Old Nov 29, 2003 | 03:58 PM
blueskiesfade609's Avatar
Default camber kit
anyone know how difficult it is to put in a camber kit in a 90 integra ls? if anyone has done it please give me some info.
Old Nov 29, 2003 | 03:59 PM
91tegrals's Avatar
i would also like to know this..
Old Nov 29, 2003 | 04:12 PM
JDMCRVTEC's Avatar
very very simple..for the front and rear..if you do the front you have to go get a alignment and have them adjust the alignment and camber asap..when I did mine the front wheels were so crooked it needed to be adjusted and such..
Old Nov 29, 2003 | 04:26 PM
typeR#0427's Avatar
Default Re: (JDMCRVTEC)
I just did my front camber kit this morning. It took an hour, but I did it myself. My car is a 95, should be relativly the same. I took the front wheel and the front strut bar off. Loosend the top bolts on the upper arm of the suspension. I then loosend the fork of the strut. And took out the bolts. Replaced everything and it was that simple. Once you get in there its pretty easy.
Old Nov 29, 2003 | 06:26 PM
Mikizzle's Avatar
what is the differnce between the 2 differnt kinds of camber kits. theres one that looks like the skunk2's and one that looks like the ingalls. how would you install the ingall style ones? i tried to see how it works but just cant figure it out
Old Nov 29, 2003 | 06:36 PM
96 Ls lnTeG's Avatar
Default Re: (grn4drgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grn4drgsr &raquo;</TD></TR><TR><TD CLASS="quote">what is the differnce between the 2 differnt kinds of camber kits. theres one that looks like the skunk2's and one that looks like the ingalls. how would you install the ingall style ones? i tried to see how it works but just cant figure it out</TD></TR></TABLE>
Skunks2 Uses the Ball joint to push it out,
Ingalls Pushes the whole Upper A Arm out Both are good Both have there ups an downs
Hopefully these pictures help good luck
Old Nov 29, 2003 | 06:40 PM
b00sted4dr's Avatar
Default Re: (96 Ls lnTeG)
For the people that have camberkits, was there a major difference in tire wear from before and after?
Old Nov 29, 2003 | 07:14 PM
garados's Avatar
Default Re: (96Ls4dr)
yes. I had about -2* of negative camber before, and it chewed up my old 712's pretty badly. I went through a set in about 7 months. Camber wear owned me then Although, the car handled incredibly well. Now, I have the camber @ -0.5* and it seems to be doing alright. I need to get an alignment, since I went off roading and hit a rock, some pot holes, and lots of other crap and threw the passenger front tire out of wack
Old Nov 29, 2003 | 07:49 PM
Default Re: (garados)
On my 91 4Dr Civic I had Steelies W/Sprint 2 1/2" With 3 Coils Cut an boy I was goin through tire Like every 3 0r 4 Monthes... Luckily Tires Were Cheap but that car handled great with My teg tire wear is alot better
Old Nov 29, 2003 | 10:01 PM
g2homboi's Avatar
for some reason, I have read that the ingalls do squeak a lot.... I installed mine, and it does squeak. My friend also installed his ingalls in his 01 Integra, and had the same squeaking problems. Haven't tried greasing them up. But do get some CAMBER KIT!!! I have a friend who ate his yoko's es100 in 4 months, with daily driving. Don't waste your tires and get a camber kit.
Old Nov 29, 2003 | 10:21 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (g2homboi)
*sigh* yet more uninformed responses.... camber does not wear out tires NEARLY as bad as incorrect toe does.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garados &raquo;</TD></TR><TR><TD CLASS="quote">yes. I had about -2* of negative camber before, and it chewed up my old 712's pretty badly. I went through a set in about 7 months. Camber wear owned me then Although, the car handled incredibly well. Now, I have the camber @ -0.5* and it seems to be doing alright. I need to get an alignment, since I went off roading and hit a rock, some pot holes, and lots of other crap and threw the passenger front tire out of wack </TD></TR></TABLE>
I went over a year, 25,000 miles on my last tires with -2.3 deg. camber in front. Alignment w/ exact toe settings is key, along w/ frequent tire rotation.
On my current ES100's I started getting some inside wear after 15,000 miles, but my last alignment showed I was around -2.5 deg. in front and -2 in back.
If I were you, I would dial it in to somewhere between -1.5 and -1.8 camber, get the toe set to factory specs, and rotate your tires every 3K-5K miles. Your car will handle way better than it does now with -0.5, and you won't have any tire wear problems.
srcv4life
Suspension & Brakes
Apr 27, 2013 12:39 PM
jdmeg6honda
Suspension & Brakes
Apr 16, 2011 10:25 AM
RedlineRex
Aug 4, 2006 05:43 AM
lsvtec_DA
Feb 25, 2004 09:59 PM
MugenHonda
Dec 27, 2002 05:40 PM
