cam seals???
Old May 17, 2004 | 07:22 PM
blueintegra90's Avatar
Default cam seals???
i just ordered a set of cam seals since mine are leaking. does anyone have pics or instructions on how to do this. this is being done on a 90 integra
Old May 17, 2004 | 07:50 PM
bubba your prison bitch's Avatar
Default Re: cam seals??? (blueintegra90)
um, a set of cam seals? there's only 1...
anyway, go to team-integra.net, there's a very good writeup with pictures on how to do this.
Old May 17, 2004 | 07:59 PM
b18c1995's Avatar
its not too difficult, on a 1-10 scale id rate it a 5, it takes a little while to do though, so be patient when you do it.
shamoo's Avatar
Will you make something up for me please?
Default Re: cam seals??? (bubba your prison bitch)
Hah, yeah, there is only one. Are you sure you're talking about the cam seal? Maybe it's something different.
Anyway the cam seal is VERY EASY to install. I can't even explain it here, it'll make it more difficult. Basically, it's like changing a tire. Remove the old one, put the new one in. That's it.
Old May 17, 2004 | 08:05 PM
Default Re: cam seals??? (shamoo)
yea its the cam seal, not the cam plug. i thought there was a seal for each cam???
Old May 17, 2004 | 08:09 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueintegra90 &raquo;</TD></TR><TR><TD CLASS="quote">yea its the cam seal, not the cam plug. i thought there was a seal for each cam???</TD></TR></TABLE>
Hmm, what's a cam plug? Anyway, if you look at the valve cover area, you can see that there is a cam plug/seal on the exhaust cam side. The intake side has the distributer on it so of course there's no seal there.
EDIT: If you are not understanding this, lemme know, I'll post up a picture.
Old May 17, 2004 | 08:15 PM
frenchy's Avatar
i think youre talking about valve seals
Old May 17, 2004 | 08:19 PM
Default Re: cam seals??? (frenchy)
im sure its the cam seal because if there wasnt one on the timing belt side oil would get all over the timing then. oh and the one on the distibutor side is the cam plug
Old May 17, 2004 | 08:43 PM
the article on team integra shows how to replace the cam plug no the cam seals
Old May 17, 2004 | 08:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueintegra90 &raquo;</TD></TR><TR><TD CLASS="quote">the article on team integra shows how to replace the cam plug no the cam seals</TD></TR></TABLE>
uh, dude you're really confused. there's the cam seal next to the vtec solenoid. then there's the valve guides or valve seals, is that what you're talking about? there's 16 of those, they go in the head... man no one knows what you're talking about.
Old May 17, 2004 | 08:52 PM
frenchy's Avatar
im f in lost
Old May 17, 2004 | 08:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubba your prison bitch &raquo;</TD></TR><TR><TD CLASS="quote">
uh, dude you're really confused. there's the cam seal next to the vtec solenoid. then there's the valve guides or valve seals, is that what you're talking about? there's 16 of those, they go in the head... man no one knows what you're talking about.</TD></TR></TABLE>
man if u look there is a seal between the cams and the cam gears. thats the cam seal if u didnt know. if there wasnt a seal there then all of ur oil would come out of the out and run down the block not to mention ruin ur timing belt. and that is the CAM PLUG not the cam seals next to the vtec solenoid. oh and the valve seals( i dont know where that cam from) because when those go out ur car smokes not leaks oil
Old May 17, 2004 | 09:00 PM
frenchy's Avatar
i wasnt diagnosing i was going off the fact that you said seals (plural) and theres only one but there are valve seals - whet was the qeustion again?
Old May 17, 2004 | 09:04 PM
there is a seal on each end of the 2 cams by the cam gears. on the other side by the distributer there is the one cam plug which is commonly mistaken for the cam seals. i jsut need some direstions and torque specs on how to change the cam seals
Old May 17, 2004 | 09:06 PM
frenchy's Avatar
okay - what kind of head
Old May 17, 2004 | 09:09 PM
its a stock 90 integra head.
Old May 17, 2004 | 09:10 PM
so really there's THREE cam seals... the one next to the vtec solenoid, and 2 on the timing belt side, one for each cam... (what motor do u have?) #24.. is that what ur talkin about? if so, looks like u just remove the cam gears and slap the new seals on..
Old May 17, 2004 | 09:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubba your prison bitch &raquo;</TD></TR><TR><TD CLASS="quote">so really there's THREE cam seals... the one next to the vtec solenoid, and 2 on the timing belt side, one for each cam... (what motor do u have?) #24.. is that what ur talkin about? if so, looks like u just remove the cam gears and slap the new seals on..
yep thats what i have need tryign to figure out is how to put them on. #24 is what i ordered. anyone know the torque specs on the cam gears.
frenchy's Avatar
rs ls gsr?
Old May 17, 2004 | 09:15 PM
its a 90 integra gs. well guess i need to order a cam plug too then jsut to be safe
Old May 17, 2004 | 09:19 PM
frenchy's Avatar
sounds like you need a helms dude - if you look hard enough online youll find one
Old May 17, 2004 | 09:54 PM
boredracer408's Avatar
get a helms and have fun!
Old May 17, 2004 | 10:13 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: cam seals??? (boredracer408)
To clarify things up:
The one next to the distributor is the CAM PLUG..
And there are (2) CAM SEALS on the opposite (timing belt side), like stated, ONE for each CAM.
And to install it, you have to have experience taking the cams out. On a scale of 1-10 I would say its about a 6. Make sure to expect your valve cover gasket and make sure that when you reinstall, everything is torqued down to spec.
-NRG
Old May 18, 2004 | 01:36 AM
Slow_Em1's Avatar
anyone know the torque specs on the cam gears.</TD></TR></TABLE>
as tight as u can get them
Old May 18, 2004 | 05:50 AM
Echo7847's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueintegra90 &raquo;</TD></TR><TR><TD CLASS="quote">anyone know the torque specs on the cam gears.</TD></TR></TABLE>
27lb-ft
