Cam Q
Old Oct 7, 2001 | 07:30 PM
Agamemnon's Avatar
New User
Default Cam Q
What kind of hp gains can you expect from swapping the intake and exhaust cams in a gsr with those from a type r (adjustable sprokets included)? Ive read that unless you have a large throttle body/ injectors / headers (etc) you wont notice too much. Also, has anyone put civic r cams in a gsr, apparently they are worth a couple more ponies as opposed to the integra spec ones.
Old Oct 7, 2001 | 07:55 PM
Stock-DC2's Avatar
New User
Default Re: Cam Q (Devin)
You will feel the different, but the most important thing to swap out is the GSR intake manifold and the header. The GSR IM is not meant for high RPM, so you won't get the most out of the R cams. Also, injector is not necessary if you are only going with R cams. I think all the B16 and B18 have the same injectors anyways.
Old Oct 7, 2001 | 09:14 PM
Agamemnon's Avatar
New User
Default Re: Cam Q (DC2-Rated)
Will you lose much low end torque with the r im? I heard that the r im only makes more power after 8000 or so....
Old Oct 8, 2001 | 01:30 AM
Stock-DC2's Avatar
New User
You won't loss too much, at least not noticeable with your *** dyno.
But the gain about 7500rpm will be well worth it.
BTW, you won't see too much gain with TypeR cams over the GSR cams in the low end anyways.
Wilka
Feb 15, 2012 08:33 AM
JDM-KIDD
Nov 17, 2011 01:38 PM
ed rex
Jan 10, 2009 08:44 AM
Sketch_hs
Aug 23, 2005 09:44 AM
forcefedb16
Nov 7, 2002 01:19 PM
