Cam Performance
Old May 21, 2005 | 04:54 PM
civic rocket's Avatar
Default Cam Performance
I have a set of Type"R" Cams and adjustable tming gears that I would like to use in a turboed B18C1 engine. Would I be able to reduce the overlap 17 Degrees GSR vs 25 degrees Type "R" to get better performance (output).
Has anyone out there tried this ?
Thanks
Old May 22, 2005 | 08:36 AM
DeltaCharlie2's Avatar
Default Re: Cam Performance (civic rocket)
With adjustable cam gears, you'll have the ability to adjust the overlap, regardless of the cams. Just do it on a dyno so you can see what your adjustments are doing to the graph.
misterpsycho
Jan 14, 2008 10:54 AM
hybridnorth
Jul 14, 2005 10:51 PM
st3alth
May 26, 2005 07:39 AM
BoostedGSRBubble
Aug 7, 2003 07:13 PM
NVBAM
May 21, 2003 09:00 AM
