A/C problem
Old Aug 23, 2010 | 05:52 PM
VIDC2's Avatar
Default A/C problem
Ok HT I have a little problem thats been racking my brains for a while......this is my 2nd integra to do this...... My a/c(condenser) fan NEVER comes on. When I turn my a/c on, the radiator fan comes on instead.....kinda like its acting as both cooling AND condenser fan.......my 99 SSBP gsr did that last year and now my 95 GSR is doing the same thing. A/C still blows cold and car doesnt overheat....but I just happened to notice that the a/c fan never ever comes on and the radiator fan comes on instead of it....anyone had this issue? I find it odd that 2 of my gsr's are doing the same thing so it must be common.....any ideas?
Old Aug 23, 2010 | 06:18 PM
fcm's Avatar
fcm
Old Fart
Default Re: A/C PROBLEM!!!!
When A/C head pressure triggers the condenser fan, both the rad fan and condenser fan should turn on.
Have you checked the condenser fan to see if it works?
Have you checked the fuse, fuse 35 - 20A, [hot at all times] in engine bay fuse box, it should be good if A/C compressor works, [same fuse]?
Have you checked the condenser fan relay? 94
Old Aug 23, 2010 | 06:25 PM
VIDC2's Avatar
checked everything but the relay......fan works, fuse is good, compressor comes on, everything else is good......i will check that relay now
Old Aug 24, 2010 | 08:24 AM
VIDC2's Avatar
Default Re: A/C problem
ok so it turned out to be the fan.....thanks bro
JerseyJohnny
Sep 2, 2015 04:00 PM
ek_silverback
Dec 22, 2008 09:29 PM
2Cleezy
Sep 2, 2005 08:48 AM
JDM_SOHC
Aug 10, 2005 09:53 PM
Nos4R2
Jan 26, 2003 09:40 PM
