A/C broken, please help.
Old Sep 30, 2004 | 11:46 AM
mintegra97's Avatar
Default A/C broken, please help.
My A/C has stopped blowing out cold air. The fan comes on still. The day before this happened it was working fine and then the next day i got in my car and no cold air. There is freon in the system and i'm pretty sure that there isn't a leak because i have had a leak before the coldness usually fades.
Does anybody know of a fuse that i could check. I looked under the steering wheel at the fuses there and could not find one for the A/C.
If anybody can help it would be very helpful because I am poor and i dont have money to get it fixed professionally.
Its for a 97 ls.
Old Sep 30, 2004 | 09:05 PM
mintegra97's Avatar
please help, its hot in TEXAS!!!
Old Oct 1, 2004 | 06:43 AM
IntegraLs94Cam's Avatar
Default Re: (mintegra97)
you can go to wal mart and buy alot of hand held fans and turn them all on around you and that could be a new ac make sure you don't have to many or you teg will be flying
Old Oct 1, 2004 | 07:18 AM
garados's Avatar
Default Re: A/C broken, please help. (mintegra97)
does the compressor wheel turn? or does it just freewheel? are you 100% sure you're not low on refrigerant?
Old Oct 1, 2004 | 07:45 AM
integra15's Avatar
Default Re: A/C broken, please help. (garados)
Yes check to see if the compressor is running, and then recharge the system anyway. It's very easy to do.
Old Oct 1, 2004 | 03:18 PM
mintegra97's Avatar
Default Re: A/C broken, please help. (integra15)
the radiator fan and the compressor fan both work. I am positive that the refrigerant is full, i used a guage on it yesterday and it was fine.
Does anybody know anything else it could be?
Old Oct 1, 2004 | 04:27 PM
s2kkid's Avatar
do this...
Turn the a/c on for awhile with the car idleing...
after several good minutes, feel the upper a/c line... Is it ice cold? sweating with water?
If its cold, then your freon is working properly.. then check the heater valve down on the heater hose. Hondas are known for the valves to have slack in them due to a bad valve, or a stretched heater control cable.
if you can still turn the cable, with it all the way cold, it may be bad... example, if its sticking open, its blending hot air, with the cool air, and when it comes out the vents, it feels like the a/c is not working properly
LoSt is BlaCk
Jul 9, 2008 03:10 PM
Mads505
Aug 29, 2007 11:58 AM
n3v3tz
Mar 8, 2004 05:20 PM
NoNOSgsr!
Aug 27, 2003 03:34 AM
NoNOSgsr!
Aug 24, 2003 01:28 AM
