built LS VTEC issue
Old Sep 22, 2010 | 11:55 AM
g0tgot's Avatar
Default built LS VTEC issue
Helping a friend.....
Lsvtec build, same specs as in the FAQ forum, same EXACT build. NO GIRDLE and stock gsr cams.
question
is it normal to have slight vibration after 7K when engaged in vtec on this build, its not major, but it is enough to feel in the gas pedal and notice it is awkwardly different.
p28 ECU with a type R basemap at 240cc
no power steering
all ARP , machine shop made us change torque on rod bolts to 30pounds with the bolt grease advd of bolt stretch.
build has 2500 miles, very clean, very good break in.
NOTE!: using LS distributor
Old Sep 22, 2010 | 12:06 PM
g0tgot's Avatar
Default Re: built LS VTEC issue
the bottom end has been balanced and rods have been shot peened (not glass peened) everything has been checked out by machine shop and all to OEM spec. nothing is oversized, and LS crank has also been polished, but not knife edged.
Old Sep 22, 2010 | 04:28 PM
brettj20's Avatar
did this start happening recently? or has it been going on since the motor was built? it might not be in your motor.
Old Sep 22, 2010 | 05:03 PM
4stagecandy's Avatar
more likely the car and not the motor, or could be the mounts
Old Sep 22, 2010 | 05:10 PM
bks84's Avatar
Loved
Are you sitting still and revving to 7k? or does this happen while moving?
Old Sep 22, 2010 | 05:18 PM
Rooftop voter's Avatar
I would guess mounts, although I have hasports and I don't notice a vibration out of the ordinary.
Old Sep 22, 2010 | 07:49 PM
1998GsRIntegra's Avatar
im suprised ehondajdm hasnt chimed in yet. ls vtec is his thing.
Old Sep 23, 2010 | 03:38 AM
AllShowNoGo727's Avatar
check the motor mounts
Old Sep 27, 2010 | 08:26 AM
g0tgot's Avatar
checked everything, found the battery was diying.... put in new battery and vibration went away... maybe was struggling for power..... i dunno, awkward well see....
Old Sep 27, 2010 | 02:09 PM
igorka_91's Avatar
If battery is duying then ure alternator is going our or posibly whent out and is not charging youre battery. OR youre battery was on its way to retireing. ID chek out alternator and se if its profucing the correcct amount of volts.
keaven07
27
Oct 23, 2012 09:23 PM
175Shot4Door
Mar 6, 2009 11:58 AM
LukieLuc
Mar 28, 2007 05:45 PM
Tuner Eddy
Feb 16, 2006 06:42 PM
KornyCivic
Nov 15, 2005 12:41 PM
