Budget mount setup
Old Mar 10, 2010 | 12:38 PM
NFM_Dm's Avatar
Default Budget mount setup
2 out of my 4 mounts are shot, I'm looking to replace them whats my best alternative on a budget. Should i replace mine with the OEM ones or buy some ebay ones?
Another question what is the best way to get the back mount (On the crossmember) bolt out? there is like no room and its tight as a son of a bitch.
Is it a waste to get the ES Mount inserts if my stock mounts are all cracked up?
Old Mar 10, 2010 | 12:57 PM
f3joel's Avatar
Default Re: Budget mount setup
If you go oem type-r ones are cheaper.
I had the car on jack stands and went from underneath to get to the rear bolt.
Cheapest method I guess would be 3m window weld and fill your old mounts with it.
Old Mar 10, 2010 | 01:10 PM
NFM_Dm's Avatar
I got some Construction Polyurethane, but that isnt cutting it for me. i dont think i waited long enough for it to dry when i did them
Old Mar 10, 2010 | 01:43 PM
GagnarTheUnruly's Avatar
I'd go with ITR mounts. Stiffer and cheaper. As far as the rear mount I haven't done it but if you search I bet you could find a how-to, or at least some information about how people have gotten them out. I hear it's not easy.
Old Mar 10, 2010 | 06:54 PM
vangaurd's Avatar
Hardrace motor mounts. 250 for the set of 5. I think they use the oem metal part and push in there own bushings but I am not sure
Old Mar 10, 2010 | 07:11 PM
1993-eg1's Avatar
I went oem and filed with windshield glue as 2 of my frands did they where a lot better don't know on cost to itr ones
Old Mar 10, 2010 | 07:55 PM
DKYamada's Avatar
thats the stupidest thing i think i've ever heard. do you really want to risk your motor dropping because your to cheap to even go to the junk yard to get decent used mounts and used windshield glue...?
if anything, just go to the junkyard, i picked up a rear mount for cheap that was in decent shape, worked fine in my car. only thing is you have to spend the time removing it from the car their, then repeat the same thing on your car.
preludeNApower
Jan 12, 2012 08:35 AM
efyou
Apr 23, 2008 03:59 PM
Spectrum24x
Jul 6, 2005 10:34 PM
Marlon88
May 8, 2005 03:40 PM
Brewer
Mar 23, 2004 07:30 PM
