broken stud, HELP!
Old Aug 19, 2005 | 04:18 PM
awps's Avatar
Default broken stud, HELP!
I was tightening my valve cover nut and i guess i tightened it too much because the bolt that is attached to the head broke. does anyone know what i will have to do to put a new stud in there? i'm assuming i can't ride around with that bolt snapped off. it's the stud in the upper left corner of the head. is it easy to replace or will i have to have someone do it. help!
Old Aug 19, 2005 | 05:09 PM
2G0S0R1's Avatar
New User
Default Re: broken stud, HELP! (awps)
easy to replace... $4 at the dealer and it just unbolts/bolts back on. U R lucky you didnt strip it and it snapped... mine is stripped and im in your same boat other than the fact that you can fix urs easy and i have to drill...
FAWK!
Old Aug 20, 2005 | 03:21 AM
awps's Avatar
Default Re: broken stud, HELP! (2G0S0R1)
how exactly does that thing come out of there? and do you know what part number it is? thanks.
Old Aug 20, 2005 | 03:25 AM
gsrious's Avatar
take off the valve cover and everything will start to make sense.
Old Aug 20, 2005 | 03:44 AM
awps's Avatar
Default Re: broken stud, HELP! (gsrious)
ok, i guess i didn't really look at the studs when i was adjusting the valves. i'm assuming it's self-explanitory once i take it off again.
Volkspeed
Apr 21, 2011 09:22 AM
ryanangelo212
Oct 27, 2010 08:02 PM
skaternak
Dec 19, 2009 08:02 PM
jwicecold
Nov 1, 2008 01:02 AM
wilsel
Dec 26, 2003 08:41 AM
