brakes
Old Feb 5, 2006 | 06:33 PM
petergriffen's Avatar
Default brakes
if i want to check to see if my brakes are worn down do i just simply remove the pads and inspect them? and if so how ?
Old Feb 5, 2006 | 06:39 PM
teg racer 877's Avatar
Default Re: brakes (petergriffen)
just take off the wheels and look at the pads, you dont need to take them out of the calipers. why do you want to check them? just replace them when they start squeelin, oem and most other pads are made to squeel when they get thin so they wont damage your rotor.
Old Feb 5, 2006 | 06:41 PM
Racermech's Avatar
if you are taking them out in inspect them, then you ming as well just replace them. No point in removing everything just to take a look. You should be able to remove the wheels and look at the pads. You need to know (or see) how big the new pads are just to give you an idea of how good/bad yours are.
tyrone
Honda S2000
Oct 29, 2005 07:47 AM
b18crx
Nov 13, 2003 10:43 AM
T3T495GSR
Apr 2, 2003 03:51 PM
metal-x
Jul 20, 2002 05:53 PM
blkbeast
Jan 14, 2002 12:58 PM
