brake problems..need help!!!!!!!!!!!!!!!
Old Mar 17, 2003 | 12:53 PM
scrap1ngsr's Avatar
Default brake problems..need help!!!!!!!!!!!!!!!
when I press on the brakes , the car braley stops but then pedal keeps on going farther down and down as i have my foot on the pedal and then i let go and press on them agian for the car to stayed stopped....what do you think is the problem?
[Modified by CivicSiR94, 10:21 PM 3/17/2003]
Old Mar 17, 2003 | 01:21 PM
scrap1ngsr's Avatar
Default Re: brake problems..need help!!!!!!!!!!!!!!! (CivicSiR94)
anyone????
Old Mar 17, 2003 | 01:25 PM
Diego Boost's Avatar
Your master cylender may be going out, have it checked ASAP.
Old Mar 17, 2003 | 01:26 PM
'94gsR's Avatar
New User
Default Re: brake problems..need help!!!!!!!!!!!!!!! (Diego Boost)
sounds like the master cylinder to me, chk the obvious by looking at how much brack fluid is in the resiviour underneath the hood, if its low it is possible to get air in the lines and cause such a problem, if there is still plenty of fluid then it is probably the master cylinder
slomob18b's Avatar
does the car shake when you depress the brake pedal hard? If so then you need to change your brake pads/rotors.
Old Mar 17, 2003 | 01:27 PM
JimBlake's Avatar
Sounds like air in your brake system. How long since you changed your brake fluid & bled the air out? Should be every 2 years.
Maybe the master cylinder is shot. Search... There's descriptions of symptoms for air vs. MC.
Old Mar 17, 2003 | 01:31 PM
scrap1ngsr's Avatar
Default Re: brake problems..need help!!!!!!!!!!!!!!! (slomob18b)
the car doesnt shake when i depress the brake pedal hard.. i just got the pads changed like a month and half goo..i checked the fluid and it was at the halfway point
Old Mar 17, 2003 | 01:32 PM
'94gsR's Avatar
New User
then it is probably the master cylinder, should only be a couple hundred bucks to replace at the max, or if your handy do it yourself, its not too bad.
Old Mar 17, 2003 | 01:37 PM
scrap1ngsr's Avatar
Default Re: brake problems..need help!!!!!!!!!!!!!!! ('94gsR)
thanks for all the feedback!!! ..keep it coming though
Old Mar 17, 2003 | 01:43 PM
Eva01's Avatar
Chalk another one up for bad master cylinder. Did this problem start fairly recently or after you had the brake work done?
Old Mar 17, 2003 | 01:52 PM
scrap1ngsr's Avatar
Default Re: brake problems..need help!!!!!!!!!!!!!!! (Eva01)
This problem just started recently , i think that i started to notice it yesterday and its gettting worse
Old Mar 17, 2003 | 03:24 PM
scrap1ngsr's Avatar
back to the top
Old Mar 17, 2003 | 05:19 PM
scrap1ngsr's Avatar
to the top agian
Old Mar 17, 2003 | 05:27 PM
TerribleOne's Avatar
Im voting for air in the brake fluid, bleed your brakes could be the problem and save you $$$, the same exact symptoom happened with all the older cars I restored super squishy pedal that keeps on giving...
Old Mar 17, 2003 | 05:58 PM
scrap1ngsr's Avatar
Default Re: brake problems..need help!!!!!!!!!!!!!!! (TerribleOne)
how much you think this would cost???
Old Mar 17, 2003 | 06:03 PM
All its gonna cost is replacing the brake fluid, you can do it yourself fairly easily you just need someone to pump the brake pdeal while you bleed...and the reason there would be air in there in the first place is because the mastercyliner IS leaking...so this would be a temporary fix...how long was the span of time it got bad in?
Old Mar 18, 2003 | 02:00 PM
scrap1ngsr's Avatar
the span that it got bad in was like a day..
Old Mar 18, 2003 | 02:17 PM
**** man sorry your gonna have to replace the master cylinder
Old Mar 18, 2003 | 02:20 PM
scrap1ngsr's Avatar
**** ...taht really that sucks , but i am still gonna try to bleed it tomm and see if that works
Old Mar 18, 2003 | 02:23 PM
.RJ's Avatar
.RJ
Old Mar 18, 2003 | 02:26 PM
scrap1ngsr's Avatar
Default Re: brake problems..need help!!!!!!!!!!!!!!! (.RJ)
how much does a master cylinder go for, about?
Old Mar 18, 2003 | 02:46 PM
Im not sure....anybody?
Old Mar 18, 2003 | 05:49 PM
slomob18b's Avatar
Not sure what kind of car you have, but if you have an acura look over here: http://www.acuraautomotiveparts.org/ and if you have a honda here: http://www.hondaautomotiveparts.com
jwlee7ucla
Apr 14, 2024 07:41 AM
jwrape
May 25, 2008 01:33 PM
thaimonkey
Jul 29, 2005 11:40 AM
mingchi69
Jun 21, 2003 11:47 AM
GSR95T
Sep 4, 2002 09:21 AM
