Brake Light Question
Old Apr 6, 2003 | 06:38 PM
babes 99 GSR's Avatar
Default Brake Light Question
Hey, does anyone ever notice their brake light staying on after the car has been started and the emergency brake been put down? I have only noticed this when it is really cold and the car has been parked for a while. It usually goes off after about ten minutes or so of driving in the cold. I checked to make sure i had plenty of brake fluid, so i'm not really sure what the problem is...or if there is a problem at all. Anyone know?
[Modified by 99GSR1980, 3:39 AM 4/7/2003]
Old Apr 6, 2003 | 06:39 PM
xteg95's Avatar
Default Re: Brake Light Question (99GSR1980)
nope check your wiring back there, maybe something isn't right.
Old Apr 6, 2003 | 06:58 PM
Scary1109's Avatar
hey cool another syracuse ht'er. it may be that your cable is sticky, and it does return all the way down quickly. hope that helps, email me if you need anything else maybe i can look at your car for ya.
-Scott
Old Apr 6, 2003 | 06:59 PM
cyphergs-r's Avatar
yes it happens to me all the time. Like you said when its really cold out it stays on for awhile then goes off. But when its warm out i dont see it. I heard a couple of other people say this happens to them as well awhile back so i think its ok.
Old Apr 6, 2003 | 07:12 PM
Hey, do you go to su? If so, what do you drive?
Old Apr 7, 2003 | 07:55 AM
JimBlake's Avatar
Default Re: Brake Light Question (xintegra01)
Also check the bracket for the little button switch at the handbrake lever. If the bracket's bent, then the switch doesn't know that the lever's down.
Old Apr 7, 2003 | 08:27 AM
Scary1109's Avatar
no, i just got out of undergrad this december, i'll be at SU for grad classes tho
Old Apr 8, 2003 | 10:44 AM
Default Re: Brake Light Question (Scary1109)
Hey, i'm in grad school at su right now! I graduated from cornell last year. Do you have aim?
Old Apr 8, 2003 | 01:38 PM
Scary1109's Avatar
i just sent ya an im, scary 1109 = me
-Scott
BlackAckeR
Dec 8, 2007 08:01 AM
btman
Oct 12, 2007 06:11 AM
xTurtle714x
Nov 28, 2004 01:57 AM
H1PNOT1C PRELUDE
Oct 18, 2004 07:36 PM
ekdriven
Oct 11, 2004 09:43 PM
