Brake Light Problem
<FONT COLOR="royalblue"> When I engage the brake petal, the lights do not turn on. I checked the sensor on the back and it seems fine. Is there a fuse I can check or something. Before it would work, but the brake light always stayed on. </FONT>
This might be a stupid question, but did you check the actual bulbs? If their fine, check the fuse box under the dashboard, on the cover of the fusebox theres a diagram that should tell you where the appropriate fuse is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjc1055 »</TD></TR><TR><TD CLASS="quote">This might be a stupid question, but did you check the actual bulbs? If their fine, check the fuse box under the dashboard, on the cover of the fusebox theres a diagram that should tell you where the appropriate fuse is.</TD></TR></TABLE>
<FONT COLOR="royalblue"> Missing the Panel.
Lights were changed. </FONT>
b18c1vtecdc2
Sep 2, 2013 09:31 PM
Sassafrass
11
Sep 4, 2003 01:18 PM
