Brake Light is ON
Old Mar 21, 2005 | 11:01 PM
AsSSLIDER's Avatar
Default Brake Light is ON
Hi, Im new to the site and I have a question regarding my Brake light being on. Even though I have the e-brake down sometimes the red brake light warning light stays on. . . Does this brake light have any connection to the front brakes or is there something wrong with the e brake. BTW I have a 2000 GSR and weather is at a freezing lvl
Sorry but One more thing. My clucth pedal is making a squeak noise when I press it down. Any solutions to fix this noise?
Old Mar 21, 2005 | 11:08 PM
Kendall's Avatar
Regarding the warning light for the e-brake, it's nothing to worry about, just unplug the electrical connector going to the e-brake and it'll stay off forever.
Old Mar 21, 2005 | 11:16 PM
AzninGSR's Avatar
Default Re: (Kendall)
About the squeaky clutch pedal, its probably a leaking clutch cylinder. I have the same thing, dealer quoted me 308 to replace
Old Mar 22, 2005 | 12:31 AM
virusiidx's Avatar
take out the armrest console and check if the brake light button isn't being pushed all the time, maybe even adjust it.
I don't know about the squeaky pedal, possible leak? low on fluid recently? look more into that also.
Old Mar 22, 2005 | 01:27 AM
Mattyg2's Avatar
mine squeaks and i have a cable tranny? what could it be
Old Mar 22, 2005 | 03:34 AM
Dc2 David's Avatar
i also have that e-brake light problem... only mine stayes on for a bit then after i drive the car for sometime it goes off... any ideas?
Old Mar 22, 2005 | 05:10 AM
dFreezy's Avatar
Default Re: (GSR david)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR david &raquo;</TD></TR><TR><TD CLASS="quote">i also have that e-brake light problem... only mine stayes on for a bit then after i drive the car for sometime it goes off... any ideas?</TD></TR></TABLE>check your brake fluid level, usually low levels cause this, so a quick bleed and refill will solve it. another possibility is that your master cylinder needs to be replaced, so take a look at it
Old Mar 22, 2005 | 06:12 AM
Backk InTheDA's Avatar
I hate everything
Default Re: Brake Light is ON (AsSSLIDER)
It could be this piece of plastic up under your dash. I forget the exact location, but theres this little blue plastic peice that sits between these 2 pieces of metal. That could be it. Not sure of the exact location, but try looking at that.
Old Mar 22, 2005 | 09:09 AM
sfr4dr's Avatar
I have this same problem. I'm going to check the switch on the e-brake handle first. It's funny, mine goes on when I accelerate. When it's on, pulling the e-brake has no effect on the light. Then it usually goes off when I hit the brakes and then back on when I accelerate again. After driving for about 5 minutes it goes off and stays off. Spooky
Old Mar 22, 2005 | 09:27 AM
Slo Car's Avatar
Default Re: (Mattyg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mattyg2 &raquo;</TD></TR><TR><TD CLASS="quote">mine squeaks and i have a cable tranny? what could it be</TD></TR></TABLE>
mine did this also and I was told to replace the little spring on the back side of where the pedal connects to the lever.....fixed my problem
Old Mar 22, 2005 | 09:33 AM
ernald711's Avatar
the brake light does that in my car too... when it's cold i guess it takes like a while to "warm up" or something then it turns off... definitly the sensor.
Old Mar 22, 2005 | 11:31 AM
sfr4dr's Avatar
Default Re: Brake Light is ON (ernald711)
I searched "brake light" and got 102 threads. Most say the problem is the float switch in the reservoir. First check the fluid level. If it's full, then un-plug the switch and see if that fixes it. If it does, then you can try to clean the switch to get it to operate better or get a new one.
Old Mar 22, 2005 | 12:01 PM
weak16's Avatar
i had the same problem with my brake light being on but i was low on fluid so i just filled it up and it went off. did you bleed your clutch??? thats could be why your clutch squeeks
Old Mar 22, 2005 | 03:24 PM
Irish Integra's Avatar
Default Re: Brake Light is ON (weak16)
Check your fluid leve first of all. If it's low, check your brake pads. If all is ok then check the switch at the handbrake lever.
Get out the WD40!! If the squeak is in around the pedal, it's just the pivot points, clips or springs making noise Get a look in under the dash, spray in a bit of WD40 around the pivots and springs and work the pedal until the noise stops. No $308 spent.
AzninGSR - A leak won't cause a squeak, either you had both a leak and a squeak or somebody was bullshittin you
Old Mar 23, 2005 | 03:05 AM
AzninGSR's Avatar
Default Re: Brake Light is ON (Irish Integra)
That's what the dealer says, so I'm not sure. How do I check if my cylinder is bad or if the dealer just wants my $308? BTW, the dealer messed up the wiring on my fogs, and the abs light is on all the time now.... make them fix it I will
Old Mar 23, 2005 | 07:28 PM
Mattyg2's Avatar
Default Re: (Slo Car)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slo Car &raquo;</TD></TR><TR><TD CLASS="quote">
mine did this also and I was told to replace the little spring on the back side of where the pedal connects to the lever.....fixed my problem</TD></TR></TABLE>
do u know what part # or the exact spring?
Old Mar 23, 2005 | 08:37 PM
SilverDC4's Avatar
I've had this problem...it's pretty stupid. You open up the big resvoir and you move the spacer looking cylinder, it usually gets stuck up there since it's not lubed by the brake fluid
Old Mar 23, 2005 | 11:20 PM
integ22's Avatar
Default Re: (SilverDC4)
^^^ do what he said....lube up the cylinder the floater thing slides on.
Old Mar 24, 2005 | 04:33 AM
Slo Car's Avatar
do u know what part # or the exact spring?</TD></TR></TABLE>
no I don't remember it....
Old Mar 24, 2005 | 04:45 AM
thegamemeng's Avatar
same thing happens to me , VERY annoying
Old Mar 24, 2005 | 05:28 AM
supperfly17's Avatar
yeah go under and check if your e-brake is stuck to the wheel or something, it might be frozen.
Old Mar 24, 2005 | 07:18 AM
nuWest's Avatar
Default Re: Brake Light is ON (supperfly17)
i had the same problem, today actually. car was in need of a little brake fluid. fixed and no more light
Bruce Banner
Nov 30, 2010 08:44 AM
BukThout
Apr 10, 2007 07:44 PM
DSMRacing
Mar 29, 2006 10:37 AM
zerogravitycrx
Apr 6, 2005 11:29 PM
Andrea_Aunie
Oct 20, 2001 11:46 AM
