Bouncing temperature on when i drive
Old Jan 28, 2008 | 09:36 PM
808cuban's Avatar
Default Bouncing temperature on when i drive
i just recently build a ls/vtec turbo on my integra. its tuned but with factory injectors unitl the ones i ordered arrive. ive noticed the temperature gauge in the cluster passes the center point a lot even when im just cruising. sometimes when i accelerate it begins to cool which is kinda ackward i guess. i never had problems with overheating except now. the car has a pretty big intercooler and the radiator fan works well. so i dont understand why its doing that.
advice anyone?
Old Jan 29, 2008 | 04:36 AM
jhammond_82's Avatar
Reject Papi
Default Re: Bouncing temperature on when i drive (808cuban)
change the thermostat.
Old Jan 29, 2008 | 04:59 AM
1dumbscreenname's Avatar
Default Re: Bouncing temperature on when i drive (jhammond_82)
do you have coolant in the radiator? if so then change the thermostat.
Old Jan 30, 2008 | 09:20 PM
4door integ's Avatar
it might be the sensor on the back of the head by the thermostat or it could be the thermostat hope u find out what it is
Old Jan 30, 2008 | 09:25 PM
95teg_ls's Avatar
Default Re: Bouncing temperature on when i drive (4door integ)
thermostat, buy one from the dealer, auto part store ones suck. its 21 bucks.
Old Jan 30, 2008 | 11:17 PM
808cuban's Avatar
here it gets complicated. my friend took off the thermostat. he says here in hawaii you dont really need it.
he didnt really take it off, he just cut the center and put the rest back.
should i take the whole thermostat out?
Old Jan 31, 2008 | 06:55 AM
95teg_ls's Avatar
Default Re: (808cuban)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808cuban &raquo;</TD></TR><TR><TD CLASS="quote">here it gets complicated. my friend took off the thermostat. he says here in hawaii you dont really need it.
should i take the whole thermostat out?</TD></TR></TABLE>
well if you like that bouncing temperature then you can take it out, but like its been said you need to put a new one in, put the new one in then come back here and ask more questions if it doesnt work.
Old Jan 31, 2008 | 07:36 AM
VTEC_PRODUCTION's Avatar
no thats retarded, but if you dont like your engine then do it. the tstat is a genius part and was put there for a purpose. just replace it
EB90RS
Feb 12, 2008 08:21 PM
vice
Oct 25, 2005 02:23 AM
spock_rocker
Jun 6, 2005 03:32 PM
LoooseGSR
Jul 15, 2003 10:49 PM
