bouncing tach?
Old Jul 30, 2002 | 02:40 PM
xXx Justin xXx's Avatar
Default bouncing tach?
my friend has a gsr and we can't figure out why his tach bounces around. he tried changing the entire gauge cluster with another gsr and didn't help. just put in an autometer tach and it does the same thing? thanks for the help.
Old Jul 30, 2002 | 02:49 PM
bullz's Avatar
Default Re: bouncing tach? (bstdvtecRx)
your idle might be messed up.
Old Jul 30, 2002 | 02:54 PM
Default Re: bouncing tach? (illestjr)
what do you mean the idle might be messed up. it bounces as he is driving. like going through the gears instead of steadily going up it bounces all over the place and so i has no idea when he is about to red line?
Old Jul 30, 2002 | 02:59 PM
bullz's Avatar
then check for a
vacuum leak
Leaking EGR valve
Leaking head gasket
Timing belt or pulleys worn
Camshaft lobes worn
Fuel Pump not delivering enough fuel
Or air filter clogged.
If you have touched or messed w/any of these or didn't do the maintenace required on them then that might be the problem.
Old Jul 30, 2002 | 03:53 PM
vtecdc2's Avatar
then check for a
Camshaft lobes worn
didnt know that could happen.. how often does that happen?
[Modified by HoL Lee SHieT, 4:54 PM 7/30/2002]
Old Jul 30, 2002 | 04:13 PM
GSRwBOOST's Avatar
check your plugs and wires
the stuff the other guy mentioned, but start witht he basic stuff first...
do you have any codes?
Old Jul 31, 2002 | 02:17 PM
Default Re: bouncing tach? (GSRwBOOST)
ok, i haven't had a chance to check anything yet. like i said it isn't my car. just a guy i know that works next to my work. how do you check for codes on the integra? i drive a crx so i am not familiar with it. i don't think his check engine light is on tho? is is complaining about with getting his fuel right. says it is running real bad.i don't know, i'll check it out tomorrow and get more details. thanks
Old Jul 31, 2002 | 04:29 PM
GSRaCeRbOI's Avatar
dang sounds kinda like the problem w/ my frenz prelude that I had a thread here
https://honda-tech.com/zerothread?id=242406
not many ppl knew what it was (not even the dealer) let me know if you figure anything out..
[Modified by GSRaCeRbOI, 5:30 PM 7/31/2002]
Old Jul 31, 2002 | 06:51 PM
fixhondas's Avatar
Many times a bouncing tach is caused by a poor connection at the igniter. It is common for people to replace the igniter without tightening the igniter connectors. I always pinch them with a pair of needle nosed pliers before installation. That is where I would look first. Next I would check all connections between the igniter and tach. Some Honda's with external coils feed the tach from the coil- V6's are notorious for bouncing tachs caused by a bad/failing coil.
Old Aug 1, 2002 | 03:40 PM
Default Re: bouncing tach? (fixhondas)
sorry, but bare with my stupidity....ignitor? what/ where is that at? i don't think he has messed with anything like that. changed the plug wires but thats about it when it comes to the electronics part. says it is running really lean? i have yet to look into it. never get a chance to mess with it while i am at work. thanks for the help.
Old Aug 1, 2002 | 03:47 PM
gsrvx's Avatar
New User
the ignitor or ICM is located in the distributor. Could also be the ignition coil, which is in the distributor too.
-Rod
Old Jan 14, 2003 | 11:28 AM
blacksheep's Avatar
Default Re: bouncing tach? (EVIL Teken)
Exactly what should the readings be on a good ignitor?
Old Jan 14, 2003 | 12:52 PM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: bouncing tach? (blacksheep)
I had the same problem with my LS motor. We replaced the entire distributer and the problem went away. I could have just replaced the ignitor but yard had them for like $200 with a lifetime warranty.
[Modified by arizsun21, 4:53 PM 1/14/2003]
Old Jan 20, 2003 | 11:54 PM
NiraCivicJDM's Avatar
Default Re: bouncing tach? (SOHC Beast)
is it your battery grounding ? my bro's car his battery was grounding everything and his tach was just bouncing around
Old Jan 21, 2003 | 08:10 AM
chirp3rd's Avatar
Default Re: bouncing tach? (NiraCivicJDM)
i had a bouncing tach while driving i thought it was my distributor but it was just a loose ground wire (the one on thermostat) so check that out
travbrack
Nov 8, 2010 02:55 PM
Gvis420
Dec 11, 2007 09:48 AM
Fezzie
Aug 5, 2006 05:40 AM
Silent_Destruct
Jul 19, 2006 11:13 AM
dcrolin
Oct 25, 2005 04:01 AM
