bogging at WOT when cold
Old Feb 20, 2004 | 08:34 AM
lke2drvgsr's Avatar
Default bogging at WOT when cold
everytime i go to start my car and it's cold (the engine is cold, not necessarily the temperature outside), anymore than about 40% throttle it bogs... and when i put it at WOT, it really realy bogs down and nearly stalls... anyone know what it could be?
Old Feb 20, 2004 | 09:06 AM
BolivianDc2's Avatar
Default Re: bogging at WOT when cold (lke2drvgsr)
don't go to WOT if you engine is cold....
Old Feb 20, 2004 | 09:23 AM
jfoster's Avatar
LS or GSR? At what rpms does it bog? If its a GSR Vtec will not engage until the car reaches its operating temp. That would cause it to feel sluggish after 4400rpms.
Old Feb 20, 2004 | 09:24 AM
swanny's Avatar
It's probably from you redlining it when its cold and trashing the engine.
Old Feb 20, 2004 | 09:25 AM
lke2drvgsr's Avatar
Default Re: bogging at WOT when cold (xy swany)
lol WOT and it won't go any higher than about 2500 rpm. it's a built n/a gsr.
i'm talking about when i just turn on the car and i'm sitting in neutral, not when i'm moving....
Old Feb 20, 2004 | 10:28 AM
2k1 GSR's Avatar
i think it might be a blown o2 sensor. because the same thing is happening to me. are u throwing any codes? engine check light?
Old Feb 20, 2004 | 10:30 AM
lapok25's Avatar
Spark plug, Spark plug wires, O2 sensor
Old Feb 20, 2004 | 12:02 PM
lke2drvgsr's Avatar
Default Re: bogging at WOT when cold (2k1 GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k1 GSR &raquo;</TD></TR><TR><TD CLASS="quote">i think it might be a blown o2 sensor. because the same thing is happening to me. are u throwing any codes? engine check light?</TD></TR></TABLE>
no cel, if my o2 sensor would blown then why would it be fine when the engine is warm?
spark plugs and wires were just recently replaced.
Old Feb 20, 2004 | 06:36 PM
jfoster's Avatar
The ECU runs on different loops when the engine is cold than when it is at operating temp. I think it is a closed loop for cold (just set values run through the ecu over and over. Values for fuel and air and such.) Once it reaches a high enough temp it switches over to open loop where values from the O2 and other sensors determine the amount of fuel. At least I think thats how it goes. So if that is the case the readings from the O2 sensor would not matter when it is cold.
Assuming that my above statement is true I would guess it involves your ecu. Are you by chance running an after market or chipped ecu? Maybe it has poor settings for the closed loop portion of the programming. Again, thats just a theory.
Edit: If it were an O2 sensor, wouldn't there be a cel light/code?
Old Feb 20, 2004 | 06:46 PM
lke2drvgsr's Avatar
Default Re: bogging at WOT when cold (jfoster)
mugen chipped ecu... im sellin it tho for a stock ecu so i can run hondata (which has been sitting in my room for 1 year waiting to be installed and tuned )
Old Feb 20, 2004 | 08:38 PM
jfoster's Avatar
Whats your location? What ecu are you selling?
rbizzell30
Jul 16, 2009 01:21 PM
gosu08
Jan 5, 2009 07:05 PM
zero-one
10
Apr 5, 2008 11:42 AM
esca
Sep 22, 2004 12:57 AM
ErikDaGenErik
Dec 9, 2003 08:12 PM
