Intake manifold, some parts of pcv valve hose stuck
i recently changed my pcv valve, then when i was done i saw a cut in the hose, i took the hose out
Pcv valve hoseAnd the remains of the hose got stuck inside the intake manifold
Is it a pain to remove the intake manifold? :sorry newbie right here, i never rmoved a intake manifold before, any tips? I drive a 2000 acura integra gsr, stock! Any help will do
clamp is still in there cant access coz my hand wont fit
Re: Intake manifold, some parts of pcv valve hose stuck
I remember 9 years ago, I had to go to a mechanic to do this part. However, how many miles do you have on your car? If you have at least 100k, I would take a weekend day and remove & clean out the intake manifold and throttle body along with all the sensors. So, now you are a clear path access to change your hose. Plus, you will have a clean idle perfect intake.
My car has a high pitch whine noise coming from the intake mani, I assume it is the PCV. That is my plan to remove intake manifold when I have time.
Some members in here use a long nose clamp to tackle this but I heard it is a PITA.
SnailSlowDelSol
02-21-2016 09:26 PM
gnccracer18
03-24-2008 06:14 PM
Louie_EM1
03-02-2004 08:15 AM
