Blinker help!
Old Feb 8, 2006 | 09:54 AM
Fliplm0de's Avatar
Default Blinker help!
Well my turn singals (blinkers) are working fine, however when i baught the car the previous owner made them hella fast dont want them like this is there anyway to make them normal? i've searched but not much found. thanks.
Old Feb 8, 2006 | 10:11 AM
iheartDc2's Avatar
Default Re: Blinker help! (Fliplm0de)
awww, man that sucks i hate those fast blinkers
Old Feb 8, 2006 | 10:16 AM
_WhItE_97gSr_'s Avatar
I am not too sure how to fix it, but I know it has to do something with the relays? Could you just replace it?
Anyway, hopefully someone on here can help you out.
Old Feb 8, 2006 | 10:21 AM
Fliplm0de's Avatar
Default Re: (_WhItE_97gSr_)
i heard there was a way to adjust it manually.. but im not sure about that if anyone got info lmk
Old Feb 8, 2006 | 10:33 AM
98IntegraLSNonVtec's Avatar
Default Re: (Fliplm0de)
Burnt bulb maybe? the owner could have changed the resistor/relay (not sure which one ) on the blinker, it should be a pretty big black box by the fuses under the driver side. Also, he could have taped a piece in the blinker light socket to make them blink faster. Open up the blinkers take the light out and if you see a tape or something blocking one of the metal strips remove it. It could also be L.E.D. lights, those make them blink faster as well.
Old Feb 8, 2006 | 12:21 PM
Fliplm0de's Avatar
Default Re: (98IntegraLSNonVtec)
checked that no tape.. so i would have to go out and buy an OEM relay?
Old Feb 8, 2006 | 12:35 PM
radio shack sells them.
Old Feb 8, 2006 | 12:57 PM
Fliplm0de's Avatar
thanks ^ would i just ask for any relay?
Old Feb 8, 2006 | 12:58 PM
no2unenolife's Avatar
check ur bulbs and make sure they aren't LEDs, usually its on the back signal lights
Old Feb 8, 2006 | 01:52 PM
Default Re: (no2unenolife)
https://honda-tech.com/zerothread?id=579841 hope that helps it talks about how to keep "hyper blinkers" from blinking fast it should be the same concept. Also, your stock resistor should be about 60 ohms. Turn on your turn signal listen where the click is coming from and follow it under the dash of the driver side it should lead you to a black box remove it and change the resistor might want to take it to radioshack they might be able to help, but like the other guy said check your tail lights you might have L.E.D's or hyper blinkers installed.
XSIintegra
Oct 5, 2007 07:14 AM
cb1999nj
Dec 18, 2005 02:26 PM
flex97itr
Nov 15, 2003 08:43 AM
jt2kgsr
Mar 26, 2003 02:02 PM
