bleeding coolant system
Old May 22, 2011 | 09:48 AM
cmhuber90's Avatar
Default bleeding coolant system
ive got a 91 acura integra i just put a new head in n its running hot.. ive replaced the head the gaskets, new radiator n cooling fan, water pump n temp sensor n gauge sensor.. my temp gauge doesnt work but i know my car n its still running hot many ppl have told me to bleed the coolant system but im not sure how to... i put a new half radiator in it so it doesnt have the bleeder bolt. how do i bleed the coolant system?????
Old May 22, 2011 | 10:17 AM
zman99's Avatar
Default Re: bleeding coolant system
park the car on level group
(while cold) open the rad cap
start the car and let it warm up until the fans come on
all air will escape as the rad begins to circulate the warm coolant. top directly into the open rad cap.
1/2 rad might be your problem for overheating.
Old May 22, 2011 | 10:23 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Slide heater switch to the HOT side
With a cool engine, open the radiator cap
Below the radiator theres a plug/screw, open it and drain the fluid properly into a container.
Replace plug/screw when done draining
Fill radiator with the right amount of premixed fluid, to the bottom of the fill neck
Start engine and let it run without the cap on
Let the fans kick on at least twice
Fill fluid if needed
Replace cap and check for leaks.
Test drive, and then check for leaks, fluid lost after engine is cooled again.
Have a beer
Old May 22, 2011 | 11:51 AM
cmhuber90's Avatar
it was over heating before i placed the half radiator in but ok thanks guys for the help ill check back in n let u know if it works or not n the beer is a must when workin on these damn imports
Old May 22, 2011 | 12:20 PM
ZeeVTec148's Avatar
Lol haha a beer is a must when workin on these damn imports, thats funny.
corince06
Jun 11, 2008 12:48 PM
draperj09
Mar 12, 2007 06:48 PM
gsrcxhatch
May 11, 2006 07:37 PM
migs
Dec 20, 2002 06:14 PM
drumsy
Sep 12, 2002 07:14 AM
