Big problems need help
Old Mar 29, 2009 | 06:10 PM
SlickEJ8's Avatar
Default Big problems need help
ok i was changing my speedo cable on my da9 and i was putting the cluster back in and i turn on my lights just to my sure they work. Then i noticed my temp going to hot and my gas going from f to e. then it started to smoke a little so i turned them off. now i push the horn and the same thing happens. the car wont start. Plz plz plz HELP!
Thanks
Old Mar 29, 2009 | 07:39 PM
teg racer 877's Avatar
Default Re: Big problems need help
go back and check all your work, make sure all ur plugs are plugged in and everything looks good, sounds like you had a short somewhere and burnt/melted some wires, it shouldnt be too hard to track dwn tho because you know where u were working.
Old Mar 29, 2009 | 07:51 PM
SlickEJ8's Avatar
yea ill look tomorrow.
ps if anyone has had this problem please help before i say f it and re wire everything.
thanks
Old Mar 30, 2009 | 02:26 PM
SlickEJ8's Avatar
checked.not it anyone else got input.
thanks
Old Mar 31, 2009 | 04:37 AM
SlickEJ8's Avatar
Thanks
I Figured it out bad ground ( really bad )
dthug
Feb 28, 2007 03:32 PM
civic-8442-
Jul 14, 2006 06:37 AM
remstarasianboy
Oct 25, 2005 10:15 AM
B18C1EF
12
May 31, 2005 04:49 PM
Origin
Oct 12, 2004 11:33 AM
