Big problem, need an answer QUICK!!
Old Jul 31, 2002 | 11:43 AM
VTEC-DA's Avatar
Default Car wont run, throwing 3 codes...Help!!
Alright, I have had enough of this. You may have read a previou post of mine, saying that my car idles at what seems like 50 RPM's. It doesnt stall, but it comes very close to it every couple of seconds. Now, when I start it up, it turns on, revs up and dies. It does this over and over unless I push the gas right after I turn it on, then it just idles at 50 RPM's. What is wrong?
[Modified by spacker, 9:45 PM 7/31/2002]
Old Jul 31, 2002 | 12:42 PM
VTEC-DA's Avatar
Default Re: Big problem, need an answer QUICK!! (spacker)
Alright, I just went out and pulled codes.
Code 7 - TPS sensor
Code 10 - Intake Air temperature Sensor
Code 14 - Idle Air Control valve
I just had a Skunk2 Intake Manifld professionaly installed. Could they have messed up? Could there be one big thing wrong, that sets off all these sensors?
Old Jul 31, 2002 | 01:24 PM
baonest's Avatar
most aftermarket parts screw up the ECU...
Old Jul 31, 2002 | 01:28 PM
neo1z's Avatar
Default Re: Big problem, need an answer QUICK!! (baonest)
well it sounds like it is directly related to the skunk2 im--- you need to check all the vacuum lines and such man... how reputable is this shop you went to...
Old Jul 31, 2002 | 02:17 PM
migo's Avatar
New User
Default Re: Big problem, need an answer QUICK!! (neo1z)
Have you tried re-setting the ECU
Old Jul 31, 2002 | 02:28 PM
samagon's Avatar
take it back and ask them to check and make sure that all of the wires were hooked back up, let them deal with it. your problem is obviously dirrivitive of them installing the S2 IM.
good luck
ES1_TopGun
Honda Civic (2001 - 2005)
11
Jun 13, 2016 06:26 PM
IHEARTMYHONDA91
13
Feb 20, 2008 09:20 PM
slacks
Sep 20, 2007 07:24 PM
Intellect
Feb 3, 2006 12:10 PM
beedoublejay
Aug 21, 2005 03:28 PM
