bent frame
Old Jan 13, 2009 | 10:00 PM
ILS_09's Avatar
Default bent frame
Well I've recieved an 97 ls intergra from my uncle for free, at 119k with minor dings and dents, but what the heck, it's free. So, when they were driving it from Seattle to where I live, they hit a deer one the way. Its antlers poke a hole through my radiator but I got that fixed. The problem is that the frame on top of the headlights is bent slightly, which I never noticed until I bought a new hood for it because the old one had a big *** dent on it. The new hood closed but there was about an inch of gap along the lining where you screw the bumper on, located on top of the headlights. I want to get it fix and I want to get it professionally done but that means money done the drain. Any alternatives?
Old Jan 13, 2009 | 10:32 PM
1SicLS's Avatar
Default Re: bent frame
just buy the core support and weld it in.
Old Jan 14, 2009 | 06:31 AM
neardon's Avatar
I'm a Jackass
If just the top part is hardly bent, which it sounds like it isn't bent much at all if the hood still closes. Then all you need to do is find a way to bend it back, I bent mine back with a metal pole and rope for free then got a 2000 dollar check from insurance.
Old Jan 14, 2009 | 08:03 AM
steveo135's Avatar
What it sounds like you need is a new radiator support.. you can buy a new one drill out the spot welds and have the new one welded in.. I personally would have it professionally fixed so im not going to suggest any alternatives.. except sounds like its time for a jdm front end conversion
Old Jan 14, 2009 | 08:53 AM
JDM 98 GSR's Avatar
just do the jdm front
Old Jan 17, 2009 | 05:49 PM
en00be's Avatar
lmfao i like how you make it sound easy
Old Jan 18, 2009 | 06:30 AM
4671 Hybird's Avatar
Buy the core support and I'll be up there in a couple months and will weld it in for you for free. Not entirely for free actually, I'll do it for a hot chocolate since I know it'll be cold in March. Seriously, it'll take me twenty minutes to weld it up assuming you've already got it fitted. If it's not fitted, we're probalby looking at an hour or so to make sure it's correct.
Budget wise, get one from a junkyard and you're out $21.50 ($20 for the support and $1.50 for the hot chocolate).
Old Jan 18, 2009 | 12:56 PM
crxstylin's Avatar
listen to him, take a headlight out on the side that is damaged more, attached a chain, then attach a chain to a tree and backup until its in the right spot. as long as the damage is not on the lower end of the core support (ie frame rail damage) this will work
Achenar
11
Apr 12, 2007 09:26 AM
Rajin
Apr 26, 2006 10:49 AM
xsrbase
Oct 19, 2005 08:31 AM
wizard9934
Apr 27, 2005 07:48 AM
GroundZer0 336
13
Jul 27, 2003 09:33 AM
