belt problem
Old Dec 18, 2002 | 11:54 AM
dip-set's Avatar
Default belt problem
what would be the proper procedure for replacing/tightening/loosing the belts on a 96 integra se...a/c belt,power steering belt,alternator belt...one of the three on my car is either too tight too loose or needs replacing...im getting a whistling sound at start up and occasionally while driving i hear a slight whine in the car coming from engine bay that increases with the engine rev..sorta sounds like turbo whining but hell i wish i had a turbo .if any one suggest its something else please advise me...thanks
Old Dec 18, 2002 | 06:24 PM
smkngsr's Avatar
Default Re: belt problem (teg-your-it)
when ur belt is squeeking then ur belt is lose...so tighten them up a little bit...dont do it too tight that u might messed up the bearing...clean the pulleys first then tighten them up
Old Dec 18, 2002 | 06:33 PM
JeremyL's Avatar
Default Re: belt problem (smkngsr)
or just remove ps and ac and have two less things to break
JDMhatchback20
Dec 22, 2004 08:41 AM
ek2k
Nov 26, 2004 02:09 PM
Chief Brody
Sep 14, 2003 10:40 AM
IVANITR
Jun 5, 2002 08:52 AM
cbmlsvteg
May 29, 2002 08:56 AM
