Ball joint ?
Old Feb 3, 2004 | 03:06 PM
Passaudi1.8t's Avatar
New User
Default Ball joint ?
Well, for the past 2 days, I've noticed a slight 'clunk' noise coming from the front driver's side suspension, after backing up and hitting the brakes. When the car comes to a stop, it makes the noise. If you go forward and hit the brakes, it will make this noise again. I noticed that the upper ball joint's boot had a small tear in it and some grease had started to come through the hole. I also just finished a swap and I might need to check all of the suspension bolts to make sure they're tight and not the cause of the noise... BUT... if it turns out to be the ball joint, will it need to be replaced or can you repack it with grease and put a new boot on? TIA.
Old Feb 3, 2004 | 04:08 PM
Tweakmeister's Avatar
Default Re: Ball joint ? (Dr.FeelgooDC2)
the only boots you can get are urethane replacement boots, and they are basically (crap).
run to Honda or Autozone (cheaper) and get a new balljoint. Honda wants you to have all these tools and the like, but basically they are all pressed and a major PITA.
your Helm manual will detail the process
Glock17
May 13, 2011 02:22 AM
john d ftw
Oct 6, 2006 06:55 AM
littleblue
13
Jul 27, 2006 09:15 PM
B-B-K
Oct 4, 2004 12:00 PM
Mugen Dom
13
Aug 20, 2002 11:51 AM
