Bad shocks?
Old Aug 19, 2001 | 10:30 PM
99ls's Avatar
Default Bad shocks?
Is there anyway to check if a shock is bad when it's off the car? I just bought some used Koni's and want to make sure they're in good condition.
Old Aug 20, 2001 | 06:51 AM
lundgren's Avatar
Default Re: Bad shocks? (99ls)
Do they leak oil?
Old Aug 20, 2001 | 09:15 AM
Legacy_CPA's Avatar
Default Re: Bad shocks? (lundgren)
i am planning to buy these shocks from him, so someone PLEASE answer, is there anyway to check if the shocks are bad without having them installed on a car????????????
Old Aug 20, 2001 | 09:24 AM
Rainmaker's Avatar
Default Re: Bad shocks? ([626]99-GSR-69)
What I do is push the shaft all the way in - it should give a steady resistance all the way down. Then I let go and watch the shaft come back up. It should come up slowly. I listen for strange leaking sounds and look for leaking oil. If it leaks, make noises, or springs up immediately, then there is probably something wrong with it. By the way, a very soft liquid friction whooshing sound is normal.
HTH, Rainmaker, shaft expert
Old Aug 20, 2001 | 03:18 PM
Legacy_CPA's Avatar
Default Re: Bad shocks? (Rainmaker)
james, please do what rainmaker said and check them out before you come here tomorrow...thanks
Old Aug 20, 2001 | 05:27 PM
99ls's Avatar
Thanks for the help. It looks to be working perfectly.
chrisff521
Suspension & Brakes
15
Oct 27, 2009 07:19 AM
PAID-$$$
Aug 24, 2004 10:38 AM
jArceo
Apr 27, 2004 04:43 PM
Red!ine
Oct 25, 2002 03:44 AM
d0nkeyxPunch
Aug 7, 2001 07:26 AM
