bad oil problem
Old Jan 3, 2010 | 07:13 PM
I Love My 4 door's Avatar
Default bad oil problem
So my teg, b18c1 block and b16 head, is leaking oil from no other. I try to find the highest point of the leak but there's so much I can't pinpoint it. Its all over the back side of the motor, bottom on the block (but not oilpan gasket that's brand new), and all over the axles and firewall. Can this be my rear main seal, I feel like when I push the clutch in, it bogs really bad like it wants to stall. I'm so lost right now and the weather by me sucks. Any ideas what this can be ?
Old Jan 3, 2010 | 10:46 PM
Jimmy's Avatar
Global Moderator
Default Re: bad oil problem
First thought would be grab some brake parts cleaner and get everything cleaned up so you can figure out the location of the leak..
Old Jan 4, 2010 | 06:59 AM
Mugen92Civic's Avatar
it can be your real main seal check to see if the oil box back there still has the screw because it happend to me one time i was leaking so much oil and it was just that i was missin the Screw
Old Jan 4, 2010 | 08:23 AM
white_gsr's Avatar
Check the oil pump seal. i have the same setup but no oil leaks!
92integraVTECgsr
Sep 30, 2008 04:00 PM
jakscivic
May 2, 2006 02:26 PM
CiSmoEk4
10
Dec 25, 2005 05:56 PM
GSR_Hacker
Jul 10, 2003 09:14 AM
bxsi
May 1, 2003 07:33 AM
