B20Vtec'R
Old Oct 6, 2010 | 06:42 AM
PiZZaBoY7000's Avatar
Default B20Vtec'R
ok i have a b20b and a type r head and intake and tranny and headers now i wanna get more power what do you guys suggest do i put a bigger exhaust line? do i put a bigger intake?(wich one?!) i dont really need a 500whp setup but just something that will be more powerfull
thanks for ideas and comments
Old Oct 7, 2010 | 06:23 AM
Default Re: B20Vtec'R
any help please? i looked for a edelbrock intake with a skunk2 70mm tb and a normal 2.5" with high flow cat any brand of exhaust line you recommend?
Old Oct 7, 2010 | 06:28 AM
NinJa_FLiP's Avatar
do you want to do any internal engine work? i.e. higher compression pistons, bigger cams, etc? if not, u can just go the full bolt-on route.. exhaust is def. a plus if ur using your stock exhaust with the b20vtec setup.. go atleast 2.5" piping (some will even recommend 3") but as far as mufflers go, just go with what kind of sound u prefer.. id start there before you start upgrading the im and tb..
Old Oct 7, 2010 | 07:22 AM
speedoptions.ca's Avatar
For a B20vtec N/A build you'll have to swap out the pistons and/or rods for higher compression. If your going turbo, the stock pistons are fine for a 9.2:1 static compression.
The stock type R valve train should be good enough for up to 8500 rpms, and make decent power. Extra porting of the head would be a plus. Dont skimp out on the tune, it will either make or break this motor.
Old Oct 7, 2010 | 03:14 PM
thanks thanks i actually would like i not so loud maybe more kind of a heavy sound like the new SI and i was thinking of going about 3" and internals yes but not now its still too expensive any brands you recommend? and thanks ill start by the exhaust line and check for the rest after
d00mlol
K Series
Nov 8, 2010 03:11 PM
DulinDragons
Apr 6, 2009 05:22 PM
buster0371
Nov 15, 2007 04:18 PM
CarAudioPro
Aug 29, 2006 11:25 PM
burningwrek
70
Jul 3, 2004 11:25 AM
