B20VTEC
Old Apr 17, 2013 | 06:27 PM
MegustaVtec's Avatar
Icon2 B20VTEC
I have a b20vtec stock bottom block with a b16a built with super tech flat black valves, super tech bronze valve guides, dual spring, skunk2 retainers, and blox camshafts type A. Want to know if because the cylinder head has no stock internals the aftermarket internal can make the cylinder head a bit loud.? From the intake side.
Old Apr 17, 2013 | 07:24 PM
B_Swapped93's Avatar
Default Re: B20VTEC
Troll post ?
i'll answer tho:What intake,intake manifold,exhaust and header are you running the exhaust account's for a good chunk of the sound you'r car puts out. a semibuilt engine will be louder than stock but mainly due to the exhaust the ITM and intake arm do play a part tho so what are you running ?
Old Apr 17, 2013 | 10:56 PM
Default Re: B20VTEC
The motor has the oem intake box from a Integra 99, oem 99 Si intake manifold with throttle body. High End B-Series Tri-Y Header with the Integra 99 stock muffler with catalytic.
Thanks for the response no "troll".
Old Apr 18, 2013 | 09:11 AM
S2BumpsticksGSR's Avatar
Default Re: B20VTEC
I think he's talking about noises coming from the head when the hood is up.
Possibly extra "ticky-ness" from all the aftermarket v/t.
Old Apr 18, 2013 | 10:32 AM
Default Re: B20VTEC
Could be...he just worded it oddly. In which case check you'r valve lash and make sure it's to spec.
Old Apr 18, 2013 | 01:37 PM
Default Re: B20VTEC
thanks ill check that soon.
Old Apr 18, 2013 | 01:53 PM
Default Re: B20VTEC
Adjust them using feeler gauge between cam and rocker arm, the adjustment turns out better. Service man also says to do it this way...
Old Apr 18, 2013 | 08:56 PM
minipratt89's Avatar
Default Re: B20VTEC
sounds like your valve lash is out
Old Apr 19, 2013 | 08:12 AM
cryptonik's Avatar
Default Re: B20VTEC
be sure to check your valves when the engine is cold. Like let it sit overnight and then check/adjust them in the morning.
Blaze45
Mar 10, 2011 12:39 PM
catfishracer4748
Feb 16, 2010 06:29 AM
jdm0ua
Northern California (Sales)
Jan 28, 2007 01:34 AM
KayOs
Jun 3, 2002 06:36 PM
DragII
Dec 10, 2001 11:10 AM
