b20 integra problems.
Old Dec 7, 2005 | 08:20 PM
IOSUA's Avatar
Default b20 integra problems.
ok. my friend has a b20 integra with a LS tranny. it was blowing out white smoke so we was guessing that his head gasket was blown. we opened up the head, and his head gasket was blown . so we got a new head gasket, resurfaced and cleaned the head, new intake manifold gasket, new oil and oil filter. we put everything on and dubble checked it all. then started it up and it smoked as if we didnt change the head gasket. there is no check engine light. does anyone knows what could be wrong so i can help my friend.. thanks...
Old Dec 7, 2005 | 08:21 PM
Lauj87's Avatar
did you make sure you didn't over torque the head bolts??
Old Dec 7, 2005 | 09:06 PM
b20integrapower's Avatar
Default Re: (Lauj87)
rings?
Old Dec 7, 2005 | 09:13 PM
leftcoast's Avatar
Default Re: b20 integra problems. (jdm dc2 01)
how long did you run the car for after you put everything back together? if there is still moisture in any part of the exhaust it will still exhale white smoke. if you ran it for awhile and it is still smoking i would double check torque specs, it's easy to get them mixed up with hybrids.
Old Dec 7, 2005 | 09:59 PM
IOSUA's Avatar
Default Re: b20 integra problems. (leftcoastdrifter)
my friend ran the motor for a while and it still smoked. what are the torque specs for the head on b20's??
Old Dec 7, 2005 | 10:41 PM
Lauj87's Avatar
damn can't tell you the specs right off the back..but if im guessing right i think its like 65-72 foot pounds
Old Dec 8, 2005 | 12:36 PM
does the smoke have a blueish tint to it?
Old Dec 8, 2005 | 03:34 PM
Lauj87's Avatar
under torque and over torque will lead to a head gasket leak again....check the coolent see if there's any oil mixed in yet....or start the engine and let it run for a few minutes then look at the bottom of the oil cap, if theres white bubbles then theres water in the system again.
Old Dec 8, 2005 | 03:50 PM
loudassVTEC's Avatar
cracked head or block maybe.
Old Dec 10, 2005 | 12:42 AM
IOSUA's Avatar
yea i torqued it to 72 pounds on the head.
Old Dec 10, 2005 | 12:44 AM
IOSUA's Avatar
Default Re: (b20integrapower)
its more like a light white smoke. it doesnt smoke a lot when the car is at idel. it smokes a lot when my friend revs or drives. it smokes a lot.....
Old Dec 10, 2005 | 12:45 AM
IOSUA's Avatar
Default Re: (4sd4dr)
yea i used the stock head bolts. maybe thats the reason why...
Old Dec 10, 2005 | 12:46 AM
IOSUA's Avatar
thanks for all the help everyone. im just trying to help my friend get his car running right. but when does any car run right....
Old Dec 10, 2005 | 10:33 AM
Default Re: (jdm dc2 01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm dc2 01 &raquo;</TD></TR><TR><TD CLASS="quote"> but when does any car run right....</TD></TR></TABLE>true that
Old Dec 11, 2005 | 11:55 AM
IOSUA's Avatar
ok. i checked the dipstick and the oil is not "milky". ran the car for a little bit, checked under the oil cap for water specs but its was fine. drained coolient like 3 times. checked specs on head bolts. what else i can do to see why my friend car smokes? this **** is starting to **** me off and it aint even my car. haha. anyone???
eksleeper97
Mar 17, 2012 11:16 AM
thirsk66
22
Jun 4, 2011 09:03 AM
kevinEJ
12
Feb 11, 2011 11:58 AM
touintegra1
Oct 6, 2008 02:18 PM
R6Elmo
Nov 13, 2003 04:47 PM
