B18C1 oil problem!
Old Jul 14, 2010 | 11:29 AM
thefatedhour's Avatar
Default B18C1 oil problem!
Ok i just got my first b18c1 GSR after 5 years of driving a variety of LS integras. It burns oil like crazy, and today, upon filling it up (Im NOT putting too much in), it took 3 minutes of cranking to start it, and it sputters so bad it barely runs. I pulled out the no 3 plug and the inside of the cylinder is full of oil and alot of sludge. And now it smokes really bad idling. Its obviously leaking alot of oil into the cylinder. So do i need rings? If anyone answers please be nice, im no noob to hondas but ive never done any engine internal repairs. Im gonna go pull out the other plugs now.
Old Jul 14, 2010 | 12:41 PM
Billy13's Avatar
Default Re: B18C1 oil problem!
you should do a leak down test on it to see what the problem is.
Old Jul 14, 2010 | 12:44 PM
00-Civic-Si's Avatar
valve spring seals might be going bad
Old Jul 14, 2010 | 09:42 PM
jlow125's Avatar
if not the rings or valve seals check the valve cover gasket and cylinder gaskets. I had this problem though not as severe. never hurts to do the compression test either.
Old Jul 14, 2010 | 10:43 PM
racebum's Avatar
rings guides and seals
you have a low compression condition and i can almost guarantee it. valve seals often get pointed at on here when they are only a small part of the problem. loose guides will kills seals with a quickness and the b18c is famous for toasting rings if the car is driven hard
G3teg96
Aug 20, 2011 05:00 PM
houstonteamer
Sep 13, 2009 07:23 AM
D16SohcVtec
May 11, 2009 11:43 AM
jdmdc2110
Jan 28, 2006 10:48 PM
RTW DC2R
Mar 19, 2004 09:05 AM
