B18c stalling/bogging please help!!
Old Nov 27, 2013 | 08:41 AM
Biggdaddy4233's Avatar
Default B18c stalling/bogging please help!!
Ok so the car was running fine when I bought it, I recently installed a skunk2 im pro series. There is no vacuum leaks,no surging idle. I have replaced the fuel filter,plugs,wires,blox tps it's calibrated to spec. Idk what else to check! When you are driving after it's had time to warm up when you press the gas about 25% throttle it Boggs and stalls then if you let off and press again it won't do it or if you just go wot it shoots off. Idk what else to do please someone help me out!
Old Nov 28, 2013 | 04:53 AM
tamboo's Avatar
10 Year Member
Default Re: B18c stalling/bogging please help!!
pull valve cover and check crank/cam alignment.
i had serious bogging when mine jumped a notch .
Old Nov 28, 2013 | 04:57 AM
HondaPartsHero's Avatar
Technical Hero
Is the check engine light on?
Old Nov 30, 2013 | 12:07 AM
lukasmccracken's Avatar
Also could check if the MAP and TPS sensor plugs are mixed up.
Old Dec 1, 2013 | 11:54 PM
I have no cel. And the tps was broke so I replaced it with a blox tps and calibrated it to spec 0.5v ct and 4.5v wot. And Tamboo thanks for the suggestion I will check that out and post a update.
tstevens3754
Engine Management and Tuning
Oct 23, 2012 04:27 AM
egsickz0
Mar 29, 2009 05:45 PM
jordan_civic
May 30, 2008 10:35 PM
JDM manc 10
18
Sep 21, 2006 12:42 PM
Fatcobra
Jun 9, 2006 04:50 PM
