b18c CEL code p1337 & p1457??????
hey guys i have a 2000 teg with a jdm b18c swap obd2 and these freaking codes are poping up. does anybody know what they are?
any help is great.
any help is great.
the 1337 is cause you dont have a crank sensor any more with the jdm engine.
google CKF trick it should help.
on the CKF trick dont use the blue connectors he shows. use red ones they r for small wire. Dont cut any wires. and depinning i dont think will work cause the cpu needs to see a signal. as for 1457 i have to check what that code is.
can any 1 help please i need to figure this out quick sense this is my only car.
if i swap the usdm gsr oil pump will the ckf sensor mount and work on my jdm b18c?
JAMN J
Sep 11, 2007 03:56 PM
CivicEx95
May 9, 2002 03:22 PM
