B18B vs. B18A differrence?
Old Feb 15, 2006 | 01:20 PM
  #51
gotboostedvr6's Avatar
Default Re: B18B vs. B18A differrence? (gotboostedvr6)
__________pressure plate_________disk___________throw out_____pilot
90 - 91_____same 4 all_________small spline______cable only___same 4 all
92 - 93_____same 4 all_________large spline_______cable only____same 4 all
94+_______same 4 all_________large spline_______hydro only___same 4 all
Modified by gotboostedvr6 at 5:32 PM 2/15/2006
Old Feb 15, 2006 | 02:07 PM
  #52
inline4's Avatar
Default Re: (DC4cedInducted)
B18A1= 90-93 integra RS,LS,GS
90-91 obd0, 130hp, 58mm throttle body, less "aggressive cams", minor differences in sensor locations, cable transmission(a little bit shorter gearing than b18b1 hydro tranny), small spline clutch disc, longer intake manifold runners than b18b
92-93 obd1, 140hp, 60mm throttle body, everything is almost the same as the b18b1 except for cable transmission which supposedly has the same gearing as b18b1 hydro tranny, big spline clutch disc, longer intake manifold runners than b18b1
for all b18a1 90-93 the valve cover looks like it has little humps in it instead of a smooth valve cover like the 96+ b18b1, the 94-95 b18b1 share the same valve cover as the b18a1
Uses a "pr3" ecu.
b18b1
B18B1= 94-2001 integra RS,LS,GS, SE, all rated at 142hp
obd1 for 94-95, obd2 for 96 and up, 60 mm throttle body, shorter intake manifold runners then b18a1, obd1 b18b share the same valve cover as b18a1, 96+ has the smooth valve cover, hyraulic transmission, big spline disc
Uses "p75" ecu.
Old Apr 30, 2007 | 10:32 AM
  #53
DUNKLEYMOTERSPORTS90T's Avatar
Default Re: (Edsan)
HOW DO YOU GET THE RED LINE TO CHANGE FROM 6500 TO MORE LIKE MAYBE 7000 OR 7200 THANKS TONY
Old Apr 30, 2007 | 10:58 AM
  #54
4DRmafia's Avatar
why? the cams die out at 6,800. no point making it go further anyway..
Old Oct 28, 2007 | 09:16 PM
  #55
CarFreek's Avatar
Default Re: b series (R6E6I6D)
projectTeG, your quick to call people wrong.
"lol, wrong....90-93 had 2 different gens of the b18a1".
They did have 2 different B18A1's
But they did put B18b's in the DA's.
I have the factory shop Manuel for my 92 DA, 2000 pages on the 92 only.
it does list that some 92's came with a B18b, but they only came with a slush box (an auto trany).
im sure that it was the same in 93.
Old Jan 18, 2008 | 06:02 PM
  #56
r3ptil3bynatur3's Avatar
Default Re: B18B vs. B18A differrence? (Edsan)
i am in coral spings and i drive a 96 special edition integra with a b18b engine i have done reseach the b18b has more horse power it doesnt say why but all my findings say that it is faster too
any way my real reason to be on here is that i hardly see any other tuner cars here in springs all i see are VWs and they a soooo over rate i put couple of them to rest with just a cool air intake and straight exhaust pipes i want to know if there are any integra or civic or any drives who doesnt have any thing against japanese cars
Old Jan 18, 2008 | 07:58 PM
  #57
AccordSleeperZzZ's Avatar
Default Re: B18B vs. B18A differrence? (r3ptil3bynatur3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3ptil3bynatur3 &raquo;</TD></TR><TR><TD CLASS="quote">i have done reseach the b18b has more horse power it doesnt say why but all my findings say that it is faster too </TD></TR></TABLE>
very minor cam difference(i believe the ex. cam, correct me if i'm wrong) either that and/or just tuned up a little bit.
either way, the difference is negligible.
Old Jan 18, 2008 | 08:40 PM
  #58
GsDAteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">projectTeG, your quick to call people wrong.
im sure that it was the same in 93. </TD></TR></TABLE>
That sounds like BS to me. There were no USDM/CDN 90-93 Integra's that came with a B18B1. In north america all 90-93 Integra's came with B18A1's, except for the B17 in the GSR of course.
Old Jan 21, 2008 | 04:00 PM
  #59
crxrocket's Avatar
Default Re: (GsDAteg)
hello, not sure if im even in the right thread on this but will teast the waters.
can anyone tell me if the cranks are the same spec's for a B18A1 & B18B1 ? i am only asking cuz i am rebuilding the B18B1 and the crank is scard a lil and i have a good crank from a B18A1. can i use it or not ? thx denny.
Old Apr 17, 2009 | 09:10 AM
  #60
dvs94Teg's Avatar
From: NORCAL Salinas Valley to Monterey Bay Area 831 CA
does anybody here know the appropriate idling rpm for the b18b when its been warmed up? I need to go to state ref' today.
Old Oct 27, 2010 | 11:21 AM
  #61
L.A.knowitall's Avatar
the difference is that if you pick up an car with an Automatic or Manual Transmission. The more desired is the engine that is in the LS model that has the Manual transmission, which will produce more power.
I have recently received a 91 Acura Integra LS and have been doing a lot of research trying to figure out what route I want to take in creating my ideal car. That being said what I have said about the cams per my research should be accurate.
Old Dec 11, 2010 | 10:08 AM
  #62
waxinfroggers's Avatar
Default Re: (jaydeemmmm)
Originally Posted by Chillin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydeemmmm &raquo;</TD></TR><TR><TD CLASS="quote">b18a1 = g2 1990-1993 RS LS GS Integras
b17 = g2 1992-1993 Integra GSRs
b18b1 = g3 1994+ RS LS GS Integras
If I'm not mistaken, the g2's from 90-91 were pre-OBD while 92-96 Tegs were OBD1 and 97+ Tegs were OBD2. All g2's had cable, while the g3's had hydro.</TD></TR></TABLE>
We have a winner! Well almost, OBDI was from 92-95. OBDII started in 96 and so on. Most of the other **** on this thread is bogus.
I wish I could like this hahah
Old Oct 21, 2012 | 10:38 PM
  #63
dc2TeggyKid's Avatar
extremely helpful
Old Oct 22, 2012 | 03:44 PM
  #64
DeCePtEgRa's Avatar
No CEL pre obd(or db's call it obd0) usually a red LED on ECU to read codes
CEL on obd 1 & 2 and CAN vehicles only with a few execeptions.
Old Oct 22, 2012 | 06:43 PM
  #65
jason saizan's Avatar
Ok B18a vs B18b not much difference u can take a 90 B18a put into a 2000 obd2 civic just got to kno what your doin I'd say the B18b is lil maybe 5 horsepower diff but what hurts tge older engine is tgey had crap headers compared to tge newer 94 up take the a version engine wit cable tranny buy conversion kit cable to hydro for tranny put newer throttl body wit map on it bam your done
Old Oct 23, 2012 | 07:45 AM
  #66
DAmunster671's Avatar
Default Re: B18B vs. B18A differrence? (1990acuraian)
Originally Posted by Rus1an
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990acuraian &raquo;</TD></TR><TR><TD CLASS="quote">well i bought an acura integra ls from 1990 that has a b18b1 in it. looks to be the stock engine in it. also i bought it for 350 bucks beat that.
b18b1 in 1990-93 acura integra ls special edition's and in 90-92 GS
b16a1 in late 1992 gs later gs-R
b18a1 in integra RS
honda specialest told me this </TD></TR></TABLE>
your wrong
b18a1 90-93 integra LS/RS/GS
b18b 94-01 integra LS/RS/GS
b17a 92-93 integra GSR
this honda specialist must be a dumb ****, who agrees that thats right?
i agree, i have a DA 92 Teg LS with a B18A in it! everything is legit on my title so i believe it is the stock motor that came out of my car!
Old Oct 23, 2012 | 07:49 AM
  #67
correct me if am wrong, but for stock you want it between 700 and 900!
Old Oct 23, 2012 | 03:41 PM
  #68
DeCePtEgRa's Avatar
make sure it doesn't go above 1100 rpm
Old Oct 24, 2012 | 07:44 AM
  #69
yes sir, thanks!
Old Dec 18, 2012 | 01:42 PM
  #70
Brouwere_K74's Avatar
I bought my 94 RS for 500 short throw, 2.5" stainless steel exhaust, some motor work with some shitty matrix racing seats. Just got a new motor and brakes for it. Gonna be my winter project car as long as I pick up the jeep I'm lookin at. Don't really wanna drive the teg much this winter if its supposed to be as bad as everyone is predicting
Old Dec 18, 2012 | 03:19 PM
  #71
3rdtimecharmer's Avatar
10 Year Member
Originally Posted by Honda Hick
Please search, this has been covered a million times. It's mainly head differences (cams, intake manifold bolt pattern, etc.), but some of the holes for the sensors may be different in the block (not that big of a deal but there are differences).
search is your friend.
u can even search wiki for B series motors and it goes over the specs. -_-
latinf86
Sep 5, 2006 02:04 AM
jdmintegralsvtec
Jun 19, 2006 03:37 PM
Tammy_EP3
Oct 16, 2003 02:12 PM
jdhealy
Mar 2, 2003 09:04 PM
CRXSleeper
17
Sep 17, 2002 06:42 PM
