b18a with 403s VS. a b16
Old May 6, 2005 | 01:29 AM
redDAinteg's Avatar
Default b18a with 403s VS. a b16
would the odds be on the b18a if both motors have i/h/e but the b18a has 403s also. how much of a difference would there be betwen both motors.
Old May 6, 2005 | 07:44 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: b18a with 403s VS. a b16 (redDAinteg)
torque would be substantially higher in the b18, and the addition of cams will almost even out the hp, so id say go with the b18
Old May 6, 2005 | 08:02 AM
DAmn's Avatar
Default Re: b18a with 403s VS. a b16 (benb18a)
I have a b18b with crower 403's and even with my ls tranny i still easily pull my friends b16 si. Now if you mated thaat b18a with a b16/gsr tranny on top of the cams you will be in business
Old May 6, 2005 | 08:37 AM
Qborofinest24's Avatar
hey Damn with those cams is your idle still good ??and also did you install new springs and retainers or keep the stock ones???
Old May 7, 2005 | 01:49 PM
DAmn's Avatar
Default Re: (Qborofinest24)
No i am actually running on the stock springs and retainers, some say to upgrade and some say you dont have to if you keep stock redline. I have stock redline and i have had no problem for about 10k miles so far. Idle was a bitch at first but i played with it for a bit and got it to idle ok, just a bit lumpy. Be sure that if you get cam gears that they are set at 0,0 if you want it to idle at all before tuning.
Old May 7, 2005 | 02:28 PM
Danziver's Avatar
Default Re: (DAmn)
I have 403's (stock valvetrain) and i have the skunk2 intake manifold. I am considering removing the skunk2 mani and selling it b/c i miss the torque of the stock manifold. Anybody else run into this problem?
Old May 7, 2005 | 02:35 PM
redDAinteg's Avatar
Default Re: (Danziver)
yo danziver, how is your idle wit the cams? did you have to mess around with anything? and if yes what did you mess around with ?
Old May 7, 2005 | 02:42 PM
Danziver's Avatar
Default Re: (redDAinteg)
My idle is kinda off it drops really low sometimes and other times its fine LOL. I adjusted the idle but it still drops low sometimes. Im gonna look at it more when i get the time. But basically no problems and it dosent kill, i drive it everyday. It sounds good too.
Old May 7, 2005 | 02:46 PM
redDAinteg's Avatar
so would you say this is just your OWN problem with your car? cause i would think this doesnt happen to most of the people who use the 403s. or correct me if im wrong. and also does it usually idle at 1000rpm like what the crower website says ?
Old May 7, 2005 | 02:52 PM
apok's Avatar
Yea, you're supposed to set idle at 1000 since the cams are a lot lumpier than stock. They idle ok, though even at 750, just drops down to almost choking sometimes.
Old May 7, 2005 | 06:28 PM
DAmn's Avatar
Default Re: (apok)
ya my 403's idle will drop real low form time to time but its definitely tolerable. Hey DANZIVER how did the skunk manifold perform with the cams besides the torque loss (top end wise?)
Old May 7, 2005 | 07:05 PM
shermanyang's Avatar
Default Re: (DAmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAmn &raquo;</TD></TR><TR><TD CLASS="quote">ya my 403's idle will drop real low form time to time but its definitely tolerable. Hey DANZIVER how did the skunk manifold perform with the cams besides the torque loss (top end wise?) </TD></TR></TABLE>
the skunk2 mani should give you better mid to top range power on an N/A LS. on my Turbo'd LS, the skunk2 gives me power throughout the entire power band
Old May 7, 2005 | 07:11 PM
hybrid_vtec's Avatar
Default Re: (shermanyang)
When I had 403 cams it idled like stock, but made good power!
Old May 7, 2005 | 08:57 PM
Danziver's Avatar
Default Re: (DAmn)
On top end it pulls like a beast. It makes the b18b very different powerband wise.
maczter
Feb 6, 2009 02:10 PM
Flava
May 20, 2006 04:46 AM
redINTEGRAdriver
Mar 25, 2005 08:53 AM
H.crx-si
Mar 17, 2005 01:21 PM
LU
Nov 4, 2004 07:27 AM
