B18 vs B20
What would be every thing needed to swap in a B20 engine into a 1992 gs teg. I knw tht harness and probabley ecu's need to be changed but is thr anything els such as axels or cud the stock ecu still be used?
b series will bolt up to a b series.. lol...
any of the b-series will drop right in.. if you are going from b18 to b20, your answer is yes to pretty much everything.. its just a b18 with a bigger bore
oh yeah.. i forgot.. except the b20a5.. that is NOT a REAL B series.. it came from an 88-91 prelude 2.0 si
its a wannaB20.. HAHAHA.. its more like a dual cam f series than a b series.. b20b or b20z only.. if i remember correctly
Lol thanx yosha so th ecu and wireing and everything shd work like u guys are saying sweet. The reason tht im dropin in the B20 is cus my B18A1 bent a valve so the head is bad and a friend of mine is giving me his full B20 for $100 so i just felt like droping in a newer engine with less miles and a little more torq
Thnx guys thts legit i knw a bit about hondas u knw the normal D series and some gsr stuff but i like B series so much more, but i got so much to learn still on the tunning and swaping aspect of hondas.
Get the b20b or b20z. Your only going to use the block and head. Transfer your intake and exhaust manifold from your b18a to the b20. Use every single sensor and distributer from the b18.
You mention your getting a b20a. That wil NOT work on your car so don't buy it at all.
Cool Cool Island Breezes. BOY-EE
you can use the sensors from the b20, the plugs are all the same iirc. you may have to run the iacv from the integra. you will need to swap the drivers side mount to the block from the b20 to the one from the teg. the rest is great advice, both manifolds, the throttle body, distributor etc are all from the teg. you may want to swap over to the teg dipstick too.
you can run the integra ecu, but may want to raise the fuel pressure a bit as the b20 can run a bit lean at cold start and wide open just straight up off the ls ecu.
Nameless RB26
14
Jul 29, 2009 06:10 PM
