b18 trans ?
Old Jul 17, 2008 | 04:28 PM
TMC_EF's Avatar
Default b18 trans ?
Is it possbile to use a 92 integra 5sp trans on a 95 integra engine?
Old Jul 17, 2008 | 04:35 PM
cetcivic's Avatar
no one wants to hear the truth
Default Re: b18 trans ? (TMC_EF)
90-93 cable..94-01 hydraulic trans
jturbo8316's Avatar
Yes it will line right up.
Old Jul 18, 2008 | 10:37 AM
TMC_EF's Avatar
Default Re: b18 trans ? (jturbo8316)
know my other ? is their going to be a power loss because of this
Old Jul 18, 2008 | 10:50 AM
b17rider's Avatar
the 92 tranny is cable and your 95 is hydraulic it wont work unless you get the conversion
Old Jul 18, 2008 | 11:14 AM
TMC_EF's Avatar
Default Re: b18 trans ? (b17rider)
ok Will it owrk or not ..some people me yes and some say NO ???
Old Jul 18, 2008 | 11:26 AM
Electron00's Avatar
no, it will not work unless you get all the cable tranny parts to change it from hydraulic.....which, definitely isn't worth your time. But for some reason you do this switch, you won't lose any power...the gear ratios might be a little different, but you shouldn't lose any power.
Old Jul 18, 2008 | 04:41 PM
northemt88's Avatar
Default Re: b18 trans ? (Electron00)
you can remove the clutch booster and just run a da clutch cable and then you dont have to spend money on the convertion kit, it will work great and have no power loss
Old Jul 18, 2008 | 11:19 PM
cetcivic's Avatar
Default Re: b18 trans ? (northemt88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by northemt88 &raquo;</TD></TR><TR><TD CLASS="quote">you can remove the clutch booster and just run a da clutch cable and then you dont have to spend money on the convertion kit, it will work great and have no power loss</TD></TR></TABLE> please do elaborate..^^
Old Jul 18, 2008 | 11:29 PM
northemt88's Avatar
Default Re: b18 trans ? (cetcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cetcivic &raquo;</TD></TR><TR><TD CLASS="quote"> please do elaborate..^^</TD></TR></TABLE>
basically make it into a da fire wall, get da clutch cable and remove the hydraulic cylinder behind the dc one the run the cable through the fire wall and attach it to the tranny, im not sure if you have to get the da pedal assembly or not.
92 hatchback
Welding / Fabrication
Oct 8, 2007 11:23 PM
luvs2spooge
Aug 31, 2007 06:34 AM
chrisfletcher
Sep 11, 2006 02:57 PM
BlownHatch
Jul 20, 2006 05:29 AM
littlevtec
Sep 3, 2003 02:18 AM
