b17a1 question
Old Jun 5, 2009 | 03:31 PM
91b17a1DxH/b's Avatar
Default b17a1 question
Alright guys I have searched high and low to answer this without making a post but cant seem to find anything. ON the HEAD of my b17a1 there is a water outlet that runs the top radiator hose to the radiator. Does anyone know the specific name for this piece? Its not the water outlet as that is the piece that sits over the thermostat per autozone. I would call it the thermo housing but they dont call it that. The piece im talking about has the hose that runs to the intake manifold and has the bleeder screw on it and sits underneath the dizzy. I need to know what this piece is called so I can get one. May I remind you that per autozone and everyother parts store ive called they dont have it listed and what they have listed for the WATER PORT is in actuallity the thermo housing. I need the specific name for this part so I can get my baby back up and running. Thanks .
Old Jun 6, 2009 | 07:25 AM
Circusraven's Avatar
Default Re: b17a1 question
I doubt you could get that at autozone. Just get one at the dealership, it's probably $15-$20. It's called the water outlet cover, part number 19315-PR3-000. The bleeder screw is part number 19516-PC1-000...and the 2 screws are 95701-06030-08. Good luck
Old Jun 6, 2009 | 08:07 AM
MD426's Avatar
http://www.autozone.com/autozone/cat...questid=127711
Old Jun 6, 2009 | 06:21 PM
The part you listed md is in fact the thermostat housing cover as I already said. I thought that was the part and had them get it not to mention the coolant temp sensor is actually on the wrong side. Thanks for the reply circus and I already have one on the way it was a pita to figure out what it was though. You were right ordered from browns honda and it will be here middle of next week.
Also does anyone know what would cause an injector code? The car seems a little hard to start and once it gets started its fine . Ive changed the injectors to a set of b16'as and it was still throwing the code so i switched back to the stockers which should be more or less the same. Should I try the res box next?
vern1
Honda CR-V & Element
Aug 19, 2018 02:06 PM
93grayeg
Jan 30, 2015 03:49 PM
1998GsRIntegra
Aug 15, 2012 03:19 PM
originalbadbob
Jun 8, 2004 12:46 PM
LSVTECoupe
Sep 5, 2003 01:43 AM
