B17a1
Old Jul 26, 2009 | 10:10 AM
ef-hatchcrap's Avatar
Default B17a1
I Got A CRX With An OBD1 B17A1 GSR Motor In It And I Was Wondering If Theres Anyway To Tell What Year DB2 The Motors From, The Vins Gone And The Serial#- 1300368
Old Jul 26, 2009 | 10:30 AM
Default Re: B17a1
TTT
Old Jul 26, 2009 | 12:11 PM
B18c1-China's Avatar
Default Re: B17a1
what do you mean the vin is gone? is it like rubbed off?
Old Jul 26, 2009 | 02:05 PM
KILLAB17VTEC's Avatar
Genetically Gay
Default Re: B17a1
dude is not hard to figure it out.b17a are either year 92 or 93 only.
Old Jul 26, 2009 | 03:00 PM
Default Re: B17a1
I know that im not a noob I have been in this game for a while. There is no vin stamp or tag on the block anywhere.
Old Jul 26, 2009 | 03:22 PM
dinthanonh's Avatar
Default Re: B17a1
the head should have the year on there
Old Jul 26, 2009 | 04:01 PM
Default Re: B17a1
Yeah the head says its a 91 thats why im trying to se what the block is
Old Jul 27, 2009 | 08:50 AM
dinthanonh's Avatar
Default Re: B17a1
i'll check on my bare b17 block. im sellin it, do you wanna buy it?
Old Jul 27, 2009 | 08:58 AM
FIGARILA's Avatar
Default Re: B17a1
Engines didn't come with VIN plates till 96 and up i believe. Check to see if you have B17 cams in the head. If you do there is a good chance the block belongs to the head and your engine is from a 92'.
Old Jul 27, 2009 | 09:14 AM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: B17a1
if its a b17 then the block has to be from the 92 or 93 integra gsr.
Old Jul 27, 2009 | 10:24 AM
Default Re: B17a1
Yeah I dont feel like pulling the cams out to check. Maybe when I have some money for the gaskets I might.
The ecu is throwing a code 41 and I just bought a brand new o2 for the 92 gsr.
Old Jul 27, 2009 | 12:10 PM
thumper64's Avatar
Default Re: B17a1
The B17 is fairly rare, so most likely it's a 1992 model built in 1991. On a car around 18 years old, why does it even matter?
Old Jul 27, 2009 | 12:40 PM
Default Re: B17a1
Just trying to find out information oin the motor I have never had on ebefore I like to know what I am dealing with
Old Jul 27, 2009 | 09:37 PM
98ekgsr617's Avatar
Default Re: B17a1
all i know is if its a real b17 it is extremly rare i herd they only made 2000 of them they are only usdm because at the time the gsr in japan was a 1.6l dohc vtec correct me if im wrong but im pretty sure
Old Jul 27, 2009 | 09:55 PM
Genetically Gay
Default Re: B17a1
all integra was assemble in sayama,japan.from 1985-2007 last production.they shipped them to us.
Old Jul 27, 2009 | 10:07 PM
98ekgsr617's Avatar
Default Re: B17a1
ya even if they were assembled there they were only for usdm use there was no honda integra b17...at least this is what i was always told im almost 100 percent
Old Jul 28, 2009 | 05:07 AM
Default Re: B17a1
Sweet I have a rare motor!!!!
Old Jul 30, 2009 | 07:28 AM
98ekgsr617's Avatar
Default Re: B17a1
hell ya u do 2200 to be exact man lol take care of that sht lol i got a jdm gsr and i still havnt seen a b17 wat does tha valve cover look like?
Old Jul 30, 2009 | 07:42 AM
Targa250R's Avatar
be professional
Default Re: B17a1
It's likely a '92 engine if the head was cast in '91, but it doesn't matter since the B17 was only sold in '92-93 and was identical for both years. As mentioned above, engines didn't come with VIN plates until 1996 IIRC.
The B17A1 valve cover looks exactly like the B18C1 valve cover.
Old Jul 30, 2009 | 09:02 AM
dizzzane's Avatar
Default Re: B17a1
From 90-93 in Japan, there was no GSR, only the XSi which used a B16, which is the dual cam 1.6L that 98EK is referring to. JDM B16A1's were 170 horsepower so its similar in power to the B17, but it was not called a GSR until '94. B17's were not used in Japan at any time, only USDM Intergra GSR's from 92-93 (blah blah everyone knows). Whoever said they had never seen a B17 with a Honda valve cover.. thats right, because it was never used in Japan! Again Targa is right.. head cast in 91, but put on a 92-93 block.. if you can hear VTEC engage, you know its a B17 head/B17 cams considering the B18A's (LS/GS of that generation) were non VTEC engines. I'm not really sure why you need to know if its a '92 or '93, as someone already stated, they are identical.
Old Jul 31, 2009 | 10:59 AM
Targa250R's Avatar
be professional
Default Re: B17a1
That is correct, with the addition of the RSi trim as well. Both the DA XSi and the DA RSi had the B16A engine in Japan.
The pre-OBD '90-91 B16A (no "1" suffix for JDM engines) had 158hp (160ps). The OBD-1 and newer ('92+) JDM B16A had 168hp (170ps). The B17A1 was rated at 160hp.
The 3rd-generation Integra was never called a "GSR" in Japan. The VTEC model was called "Si-VTEC" in earlier years, and "SiR-G" in later years.
All B-series valve covers were marked either "Honda" or "Honda Motor Co." whether they were originally installed in a Honda or Acura. There are a few differences among VTEC valve covers - mainly in the sizes of the "DOHC VTEC" lettering and the inclusion of the [H] symbol (USDM B17A1 and B18C1 valve covers didn't have an [H], while all other VTEC valve covers did).
Old Jul 31, 2009 | 11:25 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Default Re: B17a1
The B17A bare block is actually identical to the B16A block. But the pistons, rods, and crank are different. The B17A crank gives you about 5mm more stroke. This is where the extra .1 liter comes from. Also, the rods are shorter in order to accommodate the increased stroke. But if you use the crank and rods together, you can stroke your B16A to 1.7 liters.
The pistons are also different. But since they actually decrease compression ratio, they are not desirable for an allmotor application. B17A compression is 9.7:1. If you use these pistons in a B16A (with its shorter stroke), compresion will end up even lower. However, using B16A pistons on top of the B17A crank and rods will probably give you compression somewhere in the mid to high 10's.
This, along with the displacement increase, would certainly be helpful in a B16A. On the other hand, B16A components will fit in a B17A block just as they would in a B16A block since the block is the same.
Also the b17 has a little more torque then the b16.
b17= 118lbs torque
b16= 111lbs torque
The HP is the same.
Old Jul 31, 2009 | 02:23 PM
1992blueGSR's Avatar
Default Re: B17a1
they were usdm only, you are correct on that, but honda made about 2200 in 92, idk the number for 93 but they ended up making about 5,000 db2's, give or take a little
b17= 118lbs torque
b16= 111lbs torque
The HP is the same.
you sir are correct
good info
Old Aug 3, 2009 | 08:10 AM
98ekgsr617's Avatar
Default Re: B17a1
oo ok then i jus looked on wikipedia but i thought they would be bullsht smtimes lol they sed 2200 total b17s but idk thats good info to know thanx
Old Aug 3, 2009 | 11:03 AM
Circusraven's Avatar
Default Re: B17a1
I my B17. I just picked up some P61 pistons and rods on ebay for $19...woo!
