b17 info
Old Aug 28, 2008 | 06:45 PM
crave13k's Avatar
Default b17 info
hi i did a search but didnt come up with much info. i'd like to know what are the pros and cons between the b17 and b18 gsr. also id like to know if the internal parts are interchangeable. like the crank and what not.
Old Aug 28, 2008 | 09:32 PM
Circusraven's Avatar
Default Re: b17 info (crave13k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crave13k &raquo;</TD></TR><TR><TD CLASS="quote">hi i did a search but didnt come up with much info. i'd like to know what are the pros and cons between the b17 and b18 gsr. also id like to know if the internal parts are interchangeable. like the crank and what not. </TD></TR></TABLE>
The B17 is basically a stroked B16, pretty much identical in power. A bit lower compression ration though.
Unless you want a headache, I wouldn't bother trying to stick B17 parts in a B18c...not worth the effort.
Old Aug 28, 2008 | 10:00 PM
mr.beeks's Avatar
Default Re: b17 info (Circusraven)
b17 crank on a b16 block w/CTR pistons now thats a combo.....
shhhhhh!!!!!!!!!!!
dont tell nobody....
Old Aug 28, 2008 | 10:14 PM
Default Re: b17 info (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">b17 crank on a b16 block w/CTR pistons now thats a combo.....
shhhhhh!!!!!!!!!!!
dont tell nobody....</TD></TR></TABLE>
The B16 and B17 blocks are the same ....But yeah, crazy compression with that combo
Old Aug 28, 2008 | 11:28 PM
gibsanez's Avatar
B16 block, B17 crank, sleeved and 84mm bore......cheap 1.8 sleeper engine
Old Aug 28, 2008 | 11:40 PM
crave13k's Avatar
Default Re: b17 info (gibsanez)
well the reason im asking is because i have a gsr head and i came across a b17 short block. so will this combo work? i wanted to know if b18c parts fit in the b17. im planning on building the engine any way. so does the b17 have a longer stroke than an ls? any input is appreciated.
Old Aug 28, 2008 | 11:44 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crave13k &raquo;</TD></TR><TR><TD CLASS="quote">well the reason im asking is because i have a gsr head and i came across a b17 short block. so will this combo work? i wanted to know if b18c parts fit in the b17. im planning on building the engine any way. so does the b17 have a longer stroke than an ls? any input is appreciated. </TD></TR></TABLE>
Well, considering all the B series engines (cept B20) have the same bore, it's physically impossible a 1.7 can have a longer stroke than a 1.8.
Also, the deck heights are a lot shorter, you would be using custom rods with a 1.8 crank in the 1.6/1.7 block.
unbreakable_35
Honda S2000
10
Sep 6, 2008 11:49 PM
TegProject
Nov 27, 2007 12:18 PM
BILLY_BLING
16
Nov 6, 2007 09:48 AM
Geno
Mar 6, 2006 12:11 PM
2000r#0283
Aug 30, 2005 01:03 PM
