B16A2 engine leaking bad
Old Aug 28, 2008 | 05:45 AM
TheFamousMatt's Avatar
Default B16A2 engine leaking bad
I just got a B16A2 engine from my friends del sol. The head was warped so he took it into a local automotive shop who sent it to a machine shop to get the head shaved down to eliminate the warp. The automotive shop put a .7mm head gasket on when then put the engine back together. The head gasket isn't blown but the engine is leaking coolant and oil really badly now just from starting it. Do I just need to put a thicker head gasket on? I found a 2.6mm from HKS...i believe that was the size of it. Please help. Thanks.
Old Aug 28, 2008 | 06:25 AM
AWD Terror's Avatar
Default Re: B16A2 engine leaking bad (TheFamousMatt)
So if the head gasket itsn't blown, where is the coolant coming from? The rad?
What are your torque specs on the head studs?
Did you replace the head studs to ARP?
Old Aug 28, 2008 | 06:29 AM
neardon's Avatar
I'm a Jackass
If its a new headgasket and its leaking right away, its either the wrong head gasket or it was installed wrong.
Old Aug 28, 2008 | 06:33 AM
Default Re: B16A2 engine leaking bad (AWD Terror)
Actually Idk. Im currently in Iraq and I just got this motor since Ive been here but I havent gotten to personally look at it yet. My friend said it was torqued back to factory settings while it was at the mechanics shop. He said he thought it was the coming from the block but the block was just replaced and it didnt have any problems from the block before he took it into the shop so I think hes just mentally retarded.
Old Aug 28, 2008 | 06:34 AM
AWD Terror's Avatar
Well have your "mentally retarded" friend pin-point the origin of the leak. Until this is done, there is nothing we can do for you except guess.
Old Aug 28, 2008 | 09:12 AM
jhammond_82's Avatar
Reject Papi
yeah, the point of the leaking would be helpful.
E-AH driver
Classic Hondas
Jan 23, 2012 03:53 AM
GSR4door1
Apr 24, 2004 08:02 AM
youngkow
Dec 26, 2003 08:40 PM
integra95
Apr 18, 2003 09:14 PM
filetofit
Aug 13, 2002 08:49 PM
